Swapping accessory brackets 307 to 455
Old Jun 11, 2016 | 05:20 PM
GHOSTOWLGRID's Avatar
455 head bolts, can I remove just 1?
Can I just remove just 1 head bolt to put a studded head bolt on the corner of the engine?
Accessory bracket needs a mounting point and the 455 has a head bolt with no stud on the corner.
Old Jun 11, 2016 | 05:54 PM
307s use 1/2" head bolts. All pre-1977 Olds V8s (including your 455) use 7/16" head bolts. You need one from an earlier motor.
Also, you are aware of the mods required on the 307 brackets to fit the taller deck of the 455, right?
http://www.robertpowersmotorsports.com/G-bodyV6-V8.html
Old Jun 12, 2016 | 02:00 PM
Yep, I was reading that, plan to buy a welder to add some metal and reshape it with my grinder then put new holes.
As long as I can swap 1 head bolt with a new one for the engine that has a stud on the top of the bolt I'll be set.
Old Jul 2, 2024 | 04:22 PM
TURNA's Avatar
I know this is an old thread, But does anyone have a photo of the mod that needs to be done to the 307 AC bracket. The link above no longer works.
Thanks!
Old Jul 2, 2024 | 06:03 PM
69HO43's Avatar
And don't forget the PS pump spacer.
Old Jul 2, 2024 | 06:36 PM
TURNA's Avatar
Thank you. Any idea if this will clear the hood of a G-Body?
Old Jul 2, 2024 | 06:54 PM
69HO43's Avatar
It should. Biggest problem is the intake/carb/air cleaner is already going to be tight. You'll be pushing clearances on a stock hood if you go anything other than stock height intake.
Old Jul 2, 2024 | 07:03 PM
TURNA's Avatar
Thank you for the pics.
Looking at these pics, the tabs have to be extended about 1.5 inches?
rfpowerdude
Oct 7, 2023 11:53 AM
alsmith787
Oct 28, 2022 11:23 AM
71OldscutlassS
Feb 25, 2021 11:19 AM
Sampson
Dec 18, 2013 07:18 AM
krashx7
Jan 26, 2013 05:09 PM
