69' H/O 455 engine head bolt stud
Hey guys I have 2 question related to my 455 getting the engine back to original I have the heat riser Stove & tube to up to the air cleaner only problem I don't have the head bolt/stud to secure the top of the stove to the head (according to the assembly manual it's the middle bolt on the passenger side of the head if you count from back to front it's #3 head bolt - if your counting front to back it's the same #3 bolt --- Now will I run into any problems removing that bolt replacing it with the bolt/stud torquing it to specs will I develop a leaking problem with this head? Lastly where can I buy this head bolt/stud for my 455?
THanksalsmith787
THanksalsmith787
No problem changing one bolt at a time. Put a add in this site in parts wanted, should be no problem to find. I had lots of them when I was dealing in parts, but now sold or gave away all my parts, will double check, may have one ?
THanksalsmith787
THanksalsmith787
