69' H/O 455 engine head bolt stud
Old Oct 27, 2022 | 02:45 PM
alsmith787's Avatar
Hey guys I have 2 question related to my 455 getting the engine back to original I have the heat riser Stove & tube to up to the air cleaner only problem I don't have the head bolt/stud to secure the top of the stove to the head (according to the assembly manual it's the middle bolt on the passenger side of the head if you count from back to front it's #3 head bolt - if your counting front to back it's the same #3 bolt --- Now will I run into any problems removing that bolt replacing it with the bolt/stud torquing it to specs will I develop a leaking problem with this head? Lastly where can I buy this head bolt/stud for my 455?
THanksalsmith787
Old Oct 27, 2022 | 04:43 PM
442Harv's Avatar
No problem changing one bolt at a time. Put a add in this site in parts wanted, should be no problem to find. I had lots of them when I was dealing in parts, but now sold or gave away all my parts, will double check, may have one ?
Old Oct 27, 2022 | 05:55 PM
alsmith787's Avatar
Head bolt/stud
Harv455 thanks alot for looking👍
alsmith787
Old Oct 27, 2022 | 05:56 PM
alsmith787's Avatar
My mistake
I meant 442Harv I apologize
Old Oct 28, 2022 | 06:17 AM
69 Hurst's Avatar
Olds Fanatic
THanksalsmith787
PM me your address, I have an extra I will send you.
Old Oct 28, 2022 | 11:23 AM
442Harv's Avatar
I looked, and do not have any more bolts. Looks like 69 Hurst can help you.
Oldssupreme
Aug 15, 2016 08:42 PM
Kowal
Oct 27, 2014 07:00 PM
Sampson
Dec 18, 2013 07:18 AM
pogo69
Oct 7, 2013 06:52 AM
manny72supreme
Apr 2, 2012 03:19 PM
