Stock 67 442 engine compartments
Old Feb 16, 2013 | 09:48 AM
squirell's Avatar
Govt slave
Hi Guys,
Doing a Big block conversion on my Cutlass and going for the stock look.
Can any of you post close up pics of stock 67 442 engine compartments ?
I know the air cleaners came chrome either open element or chrome snorkel closed.
Did any 67 442's come with chrome valve covers ?
Was there any aluminum intake option ?
Who makes the closest to correct Bronze paint ?
Thanks,
Matt
Old Feb 16, 2013 | 02:09 PM
wmachine's Avatar
Trying to remember member
And chrome "closed" with *no* snorkel
W30 only
No.
Old Feb 16, 2013 | 03:45 PM
501Paratrooper's Avatar
Squirell, check this thread out it"ll help you make a decision. I used the Rustoleum Aged Copper.
https://classicoldsmobile.com/forums...ock-color.html
Old Feb 16, 2013 | 04:13 PM
squirell's Avatar
Govt slave
wmachine...very nice , thank you.
501Paratrooper...I think the rustoleum looks best,
Did you VHT clear yours ?
Old Feb 16, 2013 | 04:26 PM
lemoldsnut's Avatar
I have used Fusick and Supercars unlimited paint. I recommend paint the engine assembly first with cast iron manifold paint first. It will then be all the same color and be as close to a raw casting color as possible. Then paint it with the copper. It will take less to cover and it will look very good.
Open element air cleaner came on stick shift cars. Close element with a snorkle and the no snorkel closed look came on automatics and don't forget the climate controled air cleaner.
Chrome valve covers only on a w-30 and the chrome ram air, air cleaner on a w-30 only also. No aluminum intakes in 67.
Hope this helps
Larry
Old Feb 16, 2013 | 04:34 PM
squirell's Avatar
Govt slave
Hope this helps
Larry
Very helpful...thanx Larry
Old Feb 16, 2013 | 06:05 PM
krooser's Avatar
Hot Rod Has Been
Great engine compartment... so nice to see the factory hose clamps used as they really look correct...
Old Feb 17, 2013 | 08:32 AM
dmiron's Avatar
chrome valve covers
Actually I had a an exception, I think. In sept of 66, I ordered a 67 w30 and was told I would have it in Oct. After 5 weeks of waiting I was told I could not get the car in w30 form until January. I said go ahead with the order without the w30. It came with chrome valve covers. I always thought it was quicker than other 442's, so maybe it came with the w30 engine but not any of the ram air etc. features. Duane
Old Feb 18, 2013 | 11:58 AM
ggoudas's Avatar
Several years ago I purchased a Chrome closed air cleaner. I have not seen any in pictures and was wondering if it was the right one for my car. 1967 442 Auto. Very informative info here as I am always learning something while browsing around. Looks like i got lucky to find one at a swap meet. Think it was $100 bucks..
Thanks WMACHINE for the info.
Old Feb 18, 2013 | 12:43 PM
wmachine's Avatar
1967 442 auto, type 1 (with snorkel, same air cleaner as '66 auto 442)
1967 442 auto, type 2 (without snorkel)
Old Feb 19, 2013 | 06:36 AM
ggoudas's Avatar
Thats it. I don't see the no snorkle often. I did get the base with my purchase. I was reading somewhere that the early 1967's were like the 1966's with the snorkle and later in the year they introduced the unit without the snorkle. Not sure of this and no dates were mentioned. As with most of the stuff going on back then sounds reasonable that they would have run the supply of snorkles out then started using the new design. By the way your open element looks great. I hope to have something under the hood that looks as tight as that.
Old Feb 19, 2013 | 08:49 AM
Run to Rund's Avatar
Look on ebay for some car magazines of that time period, such as April 67 Hi-Perf. cars. The chrome valve covers were available from parts dept. but as noted above, only used factory on the W30 cars.
Old Feb 20, 2013 | 11:28 AM
squirell's Avatar
Govt slave
Thanx guys
odddoylerules
24
Jan 22, 2014 06:35 AM
delta254
Dec 3, 2012 08:37 AM
805cut
May 3, 2012 08:11 PM
Steeb
Mar 1, 2009 03:05 PM
jetstar88_64
Feb 10, 2008 07:12 PM
