Rope seal
Old Apr 20, 2024 | 02:32 PM
Jetmek's Avatar
Rope seal
Does this look like the correct seal for a 66 425. No way that i can pack enough into the groove to keep it from pinching and preventing cap from seating.
Old Apr 20, 2024 | 02:45 PM
You cut the rope seal during install. Make sure you follow the service manual. Here's a SBO thread, your 425 should be similar.
https://classicoldsmobile.com/forums...estions-21299/
Old Apr 20, 2024 | 03:36 PM
Jetmek's Avatar
Ya. Ive done dozens of rope seal installs and this is redonkulous. I think im gonna look into the 460 ford seal retrofit
Old Apr 21, 2024 | 10:54 AM
BillK's Avatar
I have never seen a rope seal that you did not have to cut to length. The new graphite ones are a pain to cut. I use a sharp chisel on a piece of steel.
Old Apr 21, 2024 | 12:09 PM
The picture looks like the seal is too fat and won’t go into the groove?
Old Apr 21, 2024 | 12:55 PM
Jetmek's Avatar
basically …. I took another stab at it today. Figured out that i had to pull on the ends of outer covering like a Chinese finger trap it helped tighten the loose material. From there i was able to stuff it in the groove and pound it down with a large socket. Must be kevlar cause there was no cutting it with a razor. Was able to cut with hd scissors and trim loose / frayed ends enough to push into the groove. Hope for the best now i guess
rfpowerdude
Mar 7, 2022 08:33 PM
HarrySlother
Jul 9, 2021 07:13 AM
defiant1
Aug 3, 2016 02:50 PM
Inline
Body work
May 1, 2016 08:52 PM
