Rope seal
You cut the rope seal during install. Make sure you follow the service manual. Here's a SBO thread, your 425 should be similar.
https://classicoldsmobile.com/forums...estions-21299/
basically …. I took another stab at it today. Figured out that i had to pull on the ends of outer covering like a Chinese finger trap it helped tighten the loose material. From there i was able to stuff it in the groove and pound it down with a large socket. Must be kevlar cause there was no cutting it with a razor. Was able to cut with hd scissors and trim loose / frayed ends enough to push into the groove. Hope for the best now i guess
