Roller Rockers with Stock Valve Covers
I am looking to move to roller rocker arms in my rebuild but would like to keep the stock valve covers. Does anyone know which work best for this application?
1969 400cu in with a max cam lift of 550 or so....
Sean
Sean
It's been posted a million times, mostly by me. The rockers aren't what hits the valve covers, it's the poly locks.
If you're not going to tap the original 5/16 stud holes then I can get you the whole kit for under $300.00. That rockers, studs, guide plates and a shorter poly lock. But you'll probably still have to use an extra gasket to be sure.
Also make sure your machine shop cut the guides to accommodate the extra lift. Otherwise the retainers will hit the top of the guide and damage the seal along the way.
For my '69 442, I used the Harland Sharp bolt-on rockers (I believe they're the S50026A) and Fel-Pro VS13403T gaskets, which are thick plastic with built-in o-rings. Unfortunately the gaskets seem to have been discontinued, but you could get the same thickness with double rubber or cork gaskets. This all fit under the stock notched valve covers with a few dents in the baffles for clearance where needed.
-Jon
-Jon
john at rocket racing hooked me up with a prw rocker kit that fit PERFECT. i was able to use some 307 covers that were angled low on my bbo to squeese in my 83 hurst, great people to work with 262-706-3277
68442CONVERTCO
August 21st, 2021 10:22 AM
drjr56
November 29th, 2012 11:40 AM
