Roller Rockers with Stock Valve Covers
Old Mar 25, 2014 | 12:56 PM
Boilerz25's Avatar
I am looking to move to roller rocker arms in my rebuild but would like to keep the stock valve covers. Does anyone know which work best for this application?
1969 400cu in with a max cam lift of 550 or so....
Sean
Old Mar 25, 2014 | 01:14 PM
cutlassefi's Avatar
It's been posted a million times, mostly by me. The rockers aren't what hits the valve covers, it's the poly locks.
If you're not going to tap the original 5/16 stud holes then I can get you the whole kit for under $300.00. That rockers, studs, guide plates and a shorter poly lock. But you'll probably still have to use an extra gasket to be sure.
Also make sure your machine shop cut the guides to accommodate the extra lift. Otherwise the retainers will hit the top of the guide and damage the seal along the way.
Old Mar 25, 2014 | 04:16 PM
Jonb442's Avatar
For my '69 442, I used the Harland Sharp bolt-on rockers (I believe they're the S50026A) and Fel-Pro VS13403T gaskets, which are thick plastic with built-in o-rings. Unfortunately the gaskets seem to have been discontinued, but you could get the same thickness with double rubber or cork gaskets. This all fit under the stock notched valve covers with a few dents in the baffles for clearance where needed.
-Jon
Old Mar 25, 2014 | 04:41 PM
Smitty275's Avatar
Engine Builder
FelPro still makes the thick gasket. The part number has changed. Don't know it off top of my head though.
Old Apr 11, 2014 | 05:55 AM
83-425's Avatar
Sean
john at rocket racing hooked me up with a prw rocker kit that fit PERFECT. i was able to use some 307 covers that were angled low on my bbo to squeese in my 83 hurst, great people to work with 262-706-3277
Old Apr 12, 2014 | 07:27 PM
442rocketdave's Avatar
Edelbrock makes a great pair of .250 thick gaskets and the part number is #7598 and they will give you the extra clearance you need with the baffles.
Old Apr 27, 2014 | 07:08 PM
ds00469's Avatar
I had some clearance issues with my valve covers and I used Edelbrock Valve cover gaskets 7598, they are 0.250 in. thick. Summitracing part number EDL-7598.
68442CONVERTCO
Aug 21, 2021 10:22 AM
drjr56
Nov 29, 2012 11:40 AM
W31driver
Sep 20, 2012 04:44 PM
skryla
Dec 2, 2011 01:12 PM
oldzy
May 30, 2011 06:06 AM
