Roller Lifter Interchangability
Old Jul 13, 2024 | 06:03 PM
DanV's Avatar
Apologies if this is covered elsewhere and I am too stupid to find it, but I am looking around at various solid roller lifters and notice a lot of manufacturers list olds and pontiac for the same part, yet others such as comp cams list different part numbers for olds and pontiac?
does anyone know for example if comp cams 859 pontiac roller lifters can be used in an olds (comp cams part number 849) and vice versa?
Old Jul 14, 2024 | 12:35 PM
cutlassefi's Avatar
Looks like the oil band on each is in a different spot. You’d need to measure from both the bottom and top of the lobe, then to the oil band on the lifter and next to the oil hole in the lifter bore to see if the band will be in oil flow throughout its travel.
Old Jul 14, 2024 | 01:43 PM
DanV's Avatar
Thanks Mark
Strange how some manufacturers list the same part for both then.
Old Jul 16, 2024 | 08:58 AM
oddball's Avatar
It just depends on where exactly they put the band and how wide it is. They can design it to work for both, at least for stock-ish base circle/lift cams - or not. Even with an "olds" lifter you'll want to inspect to make sure the band will actually see the oil hole and doesn't pop above the top of the hole. Your specific cam can have a big impact on this also.
The size and spacing is darn similar (size is identical, I really don't know the details of Poncho spacing so the link bars may or may not be an issue) so they'll "fit" - it's just a matter of the oil band.
MartinH
Jul 1, 2022 04:30 AM
Gene kerr
Apr 21, 2022 08:56 AM
oldzy
Aug 6, 2011 05:28 AM
morrowjm4154
May 20, 2009 02:46 PM
Redog
Aug 14, 2008 06:56 PM
