Roller Cam Questions
Old Jan 24, 2016 | 10:47 PM
AlphaOmega74's Avatar
Went to go install the cam in my shortblock. When I pulled the cam out, I noticed that the front "adapter" was missing off it. Is this the correct part I need: http://www.mondellotwister.com/GS-125.gif
Is this just a press on piece and use some permatex sleeve retainer?
Also, what type of distributor gear should I be using? Here's the cam if you want to see specs: http://www.lunatipower.com/Product.aspx?id=3203&gid=137
Old Jan 26, 2016 | 04:52 PM
cutlassefi's Avatar
Does that cam not have a flange on the front?
Any melonized gear will work on that core.
Old Jan 26, 2016 | 05:09 PM
No flange. Is that Mondello part the one I need?
Old Jan 26, 2016 | 05:48 PM
cutlassefi's Avatar
Yes most likely. That cam was ground on a diesel core, that's why it doesn't have the flange it should.
Old Feb 1, 2016 | 12:01 PM
Thanks Mark. That part did the trick. Now just waiting for the cam bolt and thrust button to come in.
matt68F-85
Mar 2, 2014 08:33 AM
fly1
Dec 8, 2010 07:07 PM
442garage
Oct 20, 2008 10:25 AM
Redog
Aug 14, 2008 06:56 PM
72RocketPower
Aug 11, 2005 04:51 AM
