PCV Valve - basic question?
Old May 6, 2025 | 12:51 PM
trevor1400's Avatar
Hi,
I have two/three questions about the valve cover outlets of my 455 engine.
On the driver side there is the PCV valve connected to a hose which goes into the air filter housing. This PCV valve is mendatory and cannot change against an open air filter without connections to the filter on the carb? And there is also no other place where the PCV outlet hose can be connected?
On the passenger side there is a breather filter which is connected with the air filter housing on the carb, too. But this filter can be changed against an open filter if you don’t pay attention to eviromental concerns. Is this thought correct?
Thank you!
Trevor
Old May 6, 2025 | 02:24 PM
66SportCoupe's Avatar
PCV should be connected to the base of the carb or direct to the intake manifold
The PCV needs to connect to a manifold vacuum port, connected to the air filter housing, it does nothing. The vent on the other side can connect to the air filter housing.
Old May 7, 2025 | 04:26 AM
trevor1400's Avatar
Thank you for your answers.
It looks like the PCV valve was never connected properly. At least, I've been driving this combination about 14,000 miles without any problems.
I'm just surprised that the last garage which adjusted the carb didn't notice the problem.
Old May 7, 2025 | 05:31 AM
Make sure you connect the PCV valve. It allows your crankcase to vent. Without it you might get gaskets that seep. Before PCV valves they used road draft tubes and vented the crankcase below the engine.
Old May 7, 2025 | 05:49 AM
oddball's Avatar
You've got the Hot Rodder setup where both sides are just vented. This is the same as just putting breathers on each valve cover, then wrapping them with rags to catch the oil. Running them up to the air cleaner just lets the engine eat the blowby gasses instead of spreading oil in the engine bay.
Assuming there's actually a PCV valve in the driver side valve cover grommet then just connect that hose to the base of the carb. You must have the valve in that hose - the valve limits how much air passes through.
It's not critical. If everything has been find for 14k miles then you won't notice a difference by changing it - except you'll need to adjust the idle tuning because there will be a lot more air being pulled through the carb.
442Harv
Dec 26, 2023 05:26 PM
OldsTechGuy
Jul 2, 2021 04:50 PM
ddunmore81
Jun 27, 2017 09:24 AM
RetroRanger
Aug 26, 2011 06:55 AM
The_Jeremiah
Jan 24, 2008 12:11 PM
