Olds Toro pan 5 qt
Old Apr 24, 2020 | 04:40 PM
Gerald Nickels's Avatar
Olds Toro pan 5 qt
I'm installing a Toro 5 qt pan on my 65 Cutlass. I need to know if all the baffles are needed in that engine. I have ARP studs in the engine right now do I need to change them or run it like that with out the baffles Its a 455 Olds block and 400 trans.
Gerald
Old Apr 24, 2020 | 05:03 PM
cutlassefi's Avatar
Wondering why you would use that pan.
Old Apr 24, 2020 | 06:28 PM
Eddie Hansen's Avatar
X 2 I understand old school guys liked the toropan because it held an extra quart , however the design does not make for optimum performance as there is a hump in the middle, I used a stock milodan replacement pan which looks factory but holds 5 quarts plus the one for the filter makes six just like a toro pan. if its a budget thing disregard bud, use what you need to use
Old Apr 24, 2020 | 06:29 PM
weird I replied on 1 post and it seems duplicated in two places?
Old Apr 24, 2020 | 07:46 PM
11971four4two's Avatar
MOTORHEAD
You "can" run that oil pan without the factory baffles / windage tray
On the race car they "the wizard" heated and beat down a valley front to rear for the oil to drain back
Happy safe distance motoring
Old Apr 25, 2020 | 07:08 AM
Run to Rund's Avatar
I would heat and flatten the hump, and install custom baffles in the sump.
edzolz
Jul 17, 2019 04:57 AM
Achcoastal
May 12, 2018 04:42 AM
rpinnt
Feb 20, 2018 04:49 PM
edzolz
Jan 7, 2016 09:53 AM
Oldsmaniac
Jul 27, 2010 04:45 AM
