My 1971 455
My 1971 455
Hi everyone. My 1971 455 has a stuck pushrod and the rocker arm is blocked. My mechanic suggested that I replace everything, rods, rocker arms and hydraulic tappets. Where do you recommend I look for the pieces here in the States and have them delivered to Venice? Do you think it's right to replace everything? Thank you
The pushrods only touch at the two ends. There's no physical way for them to get "stuck" unless you have a much bigger problem (like a bent pushrod). If that's the case, you need to understand what the underlying cause of the problem is. The pushrod is just the symptom.
