My 1971 455
Old Jul 3, 2024 | 02:57 PM
Bob's garage's Avatar
My 1971 455
Hi everyone. My 1971 455 has a stuck pushrod and the rocker arm is blocked. My mechanic suggested that I replace everything, rods, rocker arms and hydraulic tappets. Where do you recommend I look for the pieces here in the States and have them delivered to Venice? Do you think it's right to replace everything? Thank you
Old Jul 3, 2024 | 03:58 PM
The pushrods only touch at the two ends. There's no physical way for them to get "stuck" unless you have a much bigger problem (like a bent pushrod). If that's the case, you need to understand what the underlying cause of the problem is. The pushrod is just the symptom.
Old Jul 3, 2024 | 05:02 PM
dc2x4drvr's Avatar
Welcome to CO.
Question, was the engine running normally, if so what happened?
Old Jul 3, 2024 | 06:35 PM
What does “rocker arm is blocked” mean? You need to give an accurate description of the issue in order to get any meaningful replies.
Old Jul 3, 2024 | 06:59 PM
Pictures would be even better
Old Jul 4, 2024 | 01:04 AM
I do not know. my mechanic found the oil very old and black. However, the compression is good and the engine starts and revs without problems
Old Jul 5, 2024 | 02:46 PM
Where can I find parts I need?
Old Jul 5, 2024 | 04:39 PM
If you’re asking about lifters, rocker arms and push rods, any auto parts store can get them.
Old Jul 5, 2024 | 04:40 PM
The OP is in Venice, Italy.
Old Jul 5, 2024 | 05:21 PM
exactly
Old Jul 6, 2024 | 07:33 PM
bw1339's Avatar
www.rockauto.com should have them and ships internationally.
Old Jul 6, 2024 | 11:11 PM
Ah, the location doesn’t show on my phone like it does on a real computer.
Old Jul 7, 2024 | 02:53 AM
I've buyed from Rock for my Elky in the past but, sometimes, parts wasn't correct to fit. Doesn't exist a Olds specialist ?
keyboard
Oct 31, 2024 06:42 PM
70sx455
Jun 25, 2014 10:51 AM
bdip55
May 11, 2014 06:39 AM
DennisG.
Feb 12, 2011 12:57 PM
