MSD Distributor Gear
Old Nov 23, 2017 | 10:26 PM
1970Olds442's Avatar
Hello. I have a quick question. I have an MSD 8566 Pro-Billet Distributor I'm going to put on my Olds 455 at some point. I believe I read that the distributor gear that comes with it is a .491" gear, and will cause wear issues. I also have a CAT DG-455M gear, but I believe it is also a .491" gear, so it's no better (if what I've read/heard is correct).
So, is this true? I think I need a .500" gear, correct?
Again, I believe I read somewhere that I need the MSD 85661 gear, but I don't believe they make them anymore. I've looked for them and there are a few, but they go for around $100+. If this is the gear I need for my MSD distributor, should I grab a few of them ASAP so I have them, or am I over-reacting?
Thanks for your time!!
Ray
Old Nov 24, 2017 | 07:15 AM
cutlassefi's Avatar
Do you have a roller cam and if so from where?
All MSD's use a .500 shaft on their Olds distributors. Everyone else uses a .491. Hope this helps.
AK71CutlassS
May 13, 2017 02:39 AM
f-85
Aug 9, 2013 09:22 AM
drjr56
Sep 9, 2012 08:05 PM
chris83
Aug 18, 2012 01:47 PM
redrider3304
Jul 2, 2010 09:20 PM
