motor/Frame mounts
Old Feb 26, 2009 | 02:04 PM
gthmcty1's Avatar
motor/Frame mounts
To install a BB olds where a SB olds used to be do you need different motor/frame mounts? And also what else do I need to be concerned with? Thanks in advance
Also forgive me for asking but will an Buick 455 bolt into a 67 cutlass "just curious"
Also is $550 a good price for a 67 delta 88 455 with all the accessories a good deal?
Old Feb 26, 2009 | 03:10 PM
kaz442's Avatar
Just use the 350 frame pads with the 350 motor mounts and your good to go.
Are are you sure its a 455? Might be a 425, 455 did not come around till 1968. What are the numbers above the water pump. $550 not bad if its a good runner and has all the brackets and such.
As for the buick yes it will fit but you will need buick frame bads and motor mounts. It will bolt up to your trans.
JKaz
Old Feb 26, 2009 | 03:13 PM
68Tom's Avatar
Not sure what year you're talking about, but I know '68 BB motor mounts are specific to that year and are different to the SB mounts.
But, just as a rule of thumb, I've always found that BB motor mounts are different from SB mounts.
Sorry, is that for just the 455 engine or the whole car?
Old Feb 26, 2009 | 03:22 PM
gthmcty1's Avatar
LOL just for the motor with all the accessories! I need to replace my 330 it has a slight knock above 4k RPM and i need a motor to get around immediately.
Old Feb 26, 2009 | 03:23 PM
gthmcty1's Avatar
JKaz
Thanks Kaz and 68Tom!
Old Feb 26, 2009 | 05:03 PM
citcapp's Avatar
gthmcty1,
What are you planning to use as a transmission behind the 455. What does the 330 have for a transmission now?
Old Feb 26, 2009 | 05:12 PM
gthmcty1's Avatar
Originally Posted by citcapp
gthmcty1,
It has a 350 behind it right now not going to be doing any hard launches or crazy driving right now just want to get a motor in there so I can drive it while working on it with mo motor issues or at least minor issue.
Old Feb 26, 2009 | 06:21 PM
The Olds factory parts manual (plus every single 1968 A-body I've ever owned or worked on) would disagree with that statement. For 1965-1968, there was only ONE P/N for frame mounts and only ONE P/N for motor mounts for the A-body cars. BBO and SBO used the same mount parts from the factory.
This topic has been covered here once or twice in the past:
https://classicoldsmobile.com/forums...ket-455-a.html
https://classicoldsmobile.com/forums...-question.html
https://classicoldsmobile.com/forums...wap-425-a.html
https://classicoldsmobile.com/forums...y-cutlass.html
https://classicoldsmobile.com/forums...gine-swap.html
https://classicoldsmobile.com/forums...-455-swap.html
https://classicoldsmobile.com/forums...ds-change.html
https://classicoldsmobile.com/forums...er-rocket.html
joesw31
May 31, 2015 04:17 PM
Nasty455
Mar 20, 2012 04:57 PM
78 omega 468
Aug 21, 2010 06:54 AM
TripDeuces
Jun 10, 2010 08:49 AM
flatoz
Mar 15, 2009 02:03 PM
