Which manifold for hood clearance
Old Mar 14, 2011 | 07:17 PM
oregontopcat's Avatar
Question Which manifold for hood clearance
Which Edelbrock manifold will provide adaquate hood clearance on a 1970 442 convertible with a standard hood, not an oai hood? Thanks Dave
Old Mar 15, 2011 | 06:33 AM
2blu442's Avatar
Dave, the Performer will fit just fine. Someone else will have to chime in about the Torker and thoughts on the new Air Gap RPM that's suppose to come out soon (is it out yet?). Back to the top for more comments.
John
Old Mar 15, 2011 | 06:44 PM
Manifold
Thanks John, thats what I will go with!
Old Mar 15, 2011 | 06:52 PM
crazy'boutOlds's Avatar
I know it's not the same, but, I had a torker on my 455 with a factory air cleaner on a 79 Holiday 88
Old Mar 15, 2011 | 11:12 PM
Stattiolds69's Avatar
I'd Agree with 2blu442 I had a 69' cutlass with the performer and adequet hood clearance. I was running a holley street avenger and had a Q-jet for a quick time too so i know both of those carbs should be no problem as well. Hey 2blu442, do currently own all those oldsmobiles?
Old Mar 16, 2011 | 04:53 AM
507OLDS's Avatar
If you're running the flat hood,then you don't have the OAI breather assembly. You can run a performer,torker,port-o-sonic,crosswind,or the new air-gap rpm,if it ever comes to market.
Old Mar 16, 2011 | 05:34 AM
2blu442's Avatar
Sattiolds69, yes but they are all project cars that need restored. There's still a lot of old iron in this part of the country although in the last couple years it's been going away at a much faster rate. I've been collecting project cars and parts to restore them for years, but haven't had the time or money to finish any of them yet. I know I won't be bored when I retire someday!
John
Old Mar 16, 2011 | 08:17 PM
Cool Manifolds
Thanks for all the info guys. I believe I will go with the performer as it will give the best allaround performance. I do have the flat hood but hopefully after I get this car done I will be able to pick up a OAI hood. Dave
Old Jan 31, 2014 | 10:31 AM
dal's Avatar
dal
With the OAI assembly removed, will an Air Gap & Holley double pumper fit under the W30 hood???
Thx for your help!
Old Jan 31, 2014 | 02:43 PM
507OLDS's Avatar
Yes,even with a 1" spacer,as long as you have a drop base for the air cleaner.You can run a 2" or 3" element,depending on what pieces you have.
I also run a filter top.
Old Jan 31, 2014 | 06:31 PM
orismedic's Avatar
will a holly street dominator work with a quick fuel carb on an OAI set up?
JPMDaddy
Jan 14, 2019 08:41 PM
rustycragars
Dec 25, 2016 06:06 PM
455cutlass1969
Apr 9, 2012 11:13 AM
Insom
Feb 7, 2010 08:58 PM
thomaswatk
Mar 22, 2007 01:31 PM
