lazy lifter??
Old Jul 17, 2016 | 01:08 PM
john mann's Avatar
lazy lifter??
Hi, have a question on a possible lifter problem, its a 1969 455 +40 over, about 1200 miles on it now runs perfect, it has the factory rockers on it, since new it has a lifer that ticks right from start up pass side, as it runs about 15 mins later its gone!! it slowly gets quieter then gone, you can drive it anywhere at that point and its quite even after shutdown hrs later, if it sits over night it will do the same thing, is there some additive i can put in there, i do have a new set of rockers that i could try on that side to see if that would take care of it ?? any suggestions would be great thank you john...
Old Jul 17, 2016 | 01:33 PM
Sugar Bear's Avatar
If you are using a thin oil such as 10W-30, a 15W-40 may help. Although I don't often recommend this, an oil additive from Lucas, BG or Wynn's could also help.
Are you fairly certain it is valve train noise? A small exhaust leak can sound similar and they can disappear as components expand with heat.
Good luck and keep us posted!!!
Old Jul 17, 2016 | 01:48 PM
john mann's Avatar
sugar bear, i use brad peen green oil, 10w40 yes i have had exhaust leaks and was fooled, this is for sure a rocker clack or lifter ??
Old Jul 17, 2016 | 03:02 PM
Sugar Bear's Avatar
Would not think it to be a rocker then, rather a lifter bleeding down overnight as you initially mentioned. Yes I'd try an additive Lucas, BG, Wynn's etc.
Good luck!!!
Old Jul 17, 2016 | 03:28 PM
john mann's Avatar
Thanks for the info !!
Old Jul 17, 2016 | 08:52 PM
I like to use rislone engine treatment, just follow the directions. It will cleanup and in most case fix a contaminated lifter.
Old Jul 18, 2016 | 11:01 AM
john mann's Avatar
Hey thanks so much for your input, my thought was possibly the cam lobe may be an issue ?? ive herd people say cams will go out anywhere from 100 miles to 1500 miles, but it has done this right from the stat up, so iam thinking like my 2 comments that ive got here that its just a lifter bleed down like sugar bear said and yourself !! iam going to give that stuff a try, i hope it will take care of it cuz it runs so dam good!! THANKS AGAIN TO ALL !! john..
Old Jul 18, 2016 | 01:11 PM
Sugar Bear's Avatar
Not going to say it is impossible...but it is VERY unlikely to be the camshaft. Two reasons, the noise would occur all the time vs. going away and the noise reoccurring after sitting overnight is a classic symptom of a lifter.
Old Jul 19, 2016 | 11:46 AM
john mann's Avatar
Yes, you would think that! iam going to give that stuff a try and i will post and let you guys know if it helps !! thanks to all again john...
Supernaut72
50
Feb 6, 2016 04:59 PM
Oldsragger
Dec 5, 2014 04:59 PM
4speedBench
Apr 21, 2013 05:50 PM
gearheads78
Oct 8, 2012 09:59 PM
blaker1
Apr 16, 2012 04:45 AM
