Idle Set Screw
Old Sep 8, 2013 | 05:32 PM
jeffsims's Avatar
Idle Set Screw
Alright I thought is would be a easy part to find, but not even the quadrajet shops have these....Idle Set Screw. Does anyone out there have a quadrajet that is not repairable and willing to sell the idle set screw?
Old Sep 8, 2013 | 05:43 PM
oldstata's Avatar
Justin
Do you just need the front air screws that you adjust I have several old carbs that I could get these out of
Old Sep 8, 2013 | 06:28 PM
jeffsims's Avatar
I have the 2 front air mixture screws. I need the one that sets the idle. It is located at the throttle linkage. It looks similar to the front screws, but not as long.
Old Sep 8, 2013 | 06:46 PM
You could just call Cliff Ruggles, or PM Bill Demmer - I'm sure they've got idle speed screws. These things are everywhere.
Old Oct 20, 2013 | 10:00 AM
jeffsims's Avatar
Thanks MD..I am just now catching up. I found Bill in the forum, but was not able to find Cliff.
Old Oct 20, 2013 | 10:05 AM
Cliff Ruggles: Cliff's High Performance
Bill works with Sparky, if I recall (maybe it was someone else...?): Sparky's Carburetor Service
Old Oct 20, 2013 | 06:03 PM
jeffsims's Avatar
Thanks Eric!
Old Oct 20, 2013 | 09:42 PM
BILL DEMMER's Avatar
Just the facts...
pm replied to.
a model number would be good
bill
Old Oct 21, 2013 | 12:49 AM
Is this a part you can get from the hardware store? All it takes is a machine screw with a specific thread pitch and size. Just a thought...
Old Oct 21, 2013 | 01:59 AM
nsnarsk65cutlass's Avatar
This is true.
Old Oct 21, 2013 | 02:16 PM
jeffsims's Avatar
I have thought about this and it will get me by. Before I show it though I want to make sure I have the original look.
Old Oct 21, 2013 | 02:19 PM
Do you have any mechanic shops in your area that have been in business for a long time. Most of them have a stack of cores in their store room.
Old Oct 21, 2013 | 02:22 PM
jeffsims's Avatar
Originally Posted by BILL DEMMER
pm replied to.
bill
Sent PM. Pictures are below.
Old Oct 21, 2013 | 02:24 PM
jeffsims's Avatar
Old Oct 21, 2013 | 05:43 PM
Octania's Avatar
round tag = 66-67 QJet
I have parts carbs if no one else has this handy
you need the spring also on this screw, and it does have a rounded tip, so I highly recommend the use of the correct part and not a store near-adequate item.
I'd need generous postage for it; the time to find and send the part is hard to come by.
Old Oct 21, 2013 | 08:13 PM
Just the facts...
i'll assume your carb. number is correct for your application, i'll assume your carb. number is 7027156. i'll try to remember to look for a screw and spring.
bill
Old Oct 21, 2013 | 08:16 PM
You can't read that, Bill?
I distinctly saw a "6".
Old Oct 22, 2013 | 01:09 AM
You should also look at local salvage yards. This part can be found on any GM car with a Q-jet (even the later CCC Q-jets). I had a 1990 Buick Estate wagon with an Olds 307 that had a CCC Q-jet and the idle set screw from this carburetor is identical to the ones on the Q-jets of the 60s and 70s.
Old Oct 22, 2013 | 06:56 AM
oldstata's Avatar
Justin
Is this what you need if so pm me your address
Old Oct 27, 2013 | 01:42 PM
Just the facts...
olds64: there are minor differences between various m/n qj's, length is one, head shape is another, and your e-qjet should've had a inside torx head.
oldstata: that looks like the fast idle screw and spring.
jeffsims: i have your screw and spring.
pm me,
bill
Old Oct 27, 2013 | 02:57 PM
oldstata's Avatar
Justin
The screw I had looked the same but spring is different
Very well could be the wrong one
Old Oct 28, 2013 | 12:37 AM
You are correct Bill. I knew the CCC Q-jet on my 90 Buick Estate Wagon had a torx head, I didn't know there were different lengths.
Seff
Sep 20, 2012 04:46 PM
73rocketship
Jul 6, 2012 06:45 AM
84oldsDelta88
Dec 11, 2009 06:19 AM
68Tom
Dec 4, 2008 10:20 AM
#1CutlassSupreme
Nov 20, 2008 09:04 AM
