Idle Set Screw
Idle Set Screw
Alright I thought is would be a easy part to find, but not even the quadrajet shops have these....Idle Set Screw. Does anyone out there have a quadrajet that is not repairable and willing to sell the idle set screw?
I have the 2 front air mixture screws. I need the one that sets the idle. It is located at the throttle linkage. It looks similar to the front screws, but not as long.
Cliff Ruggles: Cliff's High Performance
Bill works with Sparky, if I recall (maybe it was someone else...?): Sparky's Carburetor Service
round tag = 66-67 QJet
I have parts carbs if no one else has this handy
you need the spring also on this screw, and it does have a rounded tip, so I highly recommend the use of the correct part and not a store near-adequate item.
I'd need generous postage for it; the time to find and send the part is hard to come by.
You should also look at local salvage yards. This part can be found on any GM car with a Q-jet (even the later CCC Q-jets). I had a 1990 Buick Estate wagon with an Olds 307 that had a CCC Q-jet and the idle set screw from this carburetor is identical to the ones on the Q-jets of the 60s and 70s.
olds64: there are minor differences between various m/n qj's, length is one, head shape is another, and your e-qjet should've had a inside torx head.
oldstata: that looks like the fast idle screw and spring.
jeffsims: i have your screw and spring.
pm me,
bill
pm me,
bill
73rocketship
Jul 6, 2012 06:45 AM
84oldsDelta88
Dec 11, 2009 06:19 AM
