how to separate the trans from engine?
Old October 9th, 2011, 10:18 AM
nj_cutlass72's Avatar
i bought an engine n trans as an attached unit. I removed 6 bolts, theres a gap but i cant fully pull them apart, any suggestions? what am i missing!
nj_cutlass72 is online now
Old October 9th, 2011, 10:26 AM
442Harv's Avatar
Did you unbolt the torque converter?
442Harv is offline
Old October 9th, 2011, 10:35 AM
dont mind the question, how and where is it? im a beginner
Old October 9th, 2011, 10:37 AM
citcapp's Avatar
take off the dust cover at the underside where the engine mates to the transmission. There three bolts the connect the torque convertor to the flexplate. Rotate the engine using a large breaker bar and socket on the crank bolt at the front of the engine to access all three bolts then you can separate the engine from the transmission
citcapp is offline
Old October 9th, 2011, 12:27 PM
few friends of mine came over w an engine stand, after lifting n tugging around, it came loose.
thks all for feedback
keverson
March 25th, 2013 04:59 PM
techcote
December 25th, 2012 01:37 PM
oldzy
Wheels and Tires
November 22nd, 2011 07:07 PM
Flye
July 5th, 2009 01:28 PM
Quick Reply: how to separate the trans from engine?
