how to separate the trans from engine?
Old Oct 9, 2011 | 10:18 AM
nj_cutlass72's Avatar
i bought an engine n trans as an attached unit. I removed 6 bolts, theres a gap but i cant fully pull them apart, any suggestions? what am i missing!
Old Oct 9, 2011 | 10:26 AM
442Harv's Avatar
Did you unbolt the torque converter?
Old Oct 9, 2011 | 10:35 AM
dont mind the question, how and where is it? im a beginner
Old Oct 9, 2011 | 10:37 AM
citcapp's Avatar
take off the dust cover at the underside where the engine mates to the transmission. There three bolts the connect the torque convertor to the flexplate. Rotate the engine using a large breaker bar and socket on the crank bolt at the front of the engine to access all three bolts then you can separate the engine from the transmission
Old Oct 9, 2011 | 12:27 PM
few friends of mine came over w an engine stand, after lifting n tugging around, it came loose.
thks all for feedback
keverson
Mar 25, 2013 04:59 PM
oldzy
Wheels and Tires
Nov 22, 2011 07:07 PM
Flye
Jul 5, 2009 01:28 PM
