How about E heads
Old Mar 6, 2009 | 07:22 AM
Oldwolf's Avatar
How about E heads
I am wondering, after reading whats on the net, about E heads that they are pretty good. They have a not so good exhaust port but elswere no complaints. Are they worth concidering measured to edelbrock heads. I dont know what valve size it is. Please send me in the rigt direction.
My plans are:
Ported E heads
Forged speed pro pistons L2323F30
Comp Cams Magnum hydraulic 224;224 501, 501, 110 lobe sep.
Torker intake
Holley 750 Double pumper
Thornton exhaust manifolds (W30)
2,5 inch free fowing exhaust system
Old Mar 6, 2009 | 07:51 AM
citcapp's Avatar
Check the tech section. Click on tech at the top of the screen and go to the head section. This will give you good information. The E heads are availible in both small and large valve versions. The Toro's came with big valves. I went with the edelbrock heads on both of my 455's after pricing the porting, new valve seats, valves etc. I found in my area it cost nearly as much building a set of cast heads as buying the aluminum heads. Just my opinion. Where are you located? Someone close to you might have a set of C heads or large valve E heads for sale near your. They are costly to ship because of the weight.
Old Mar 6, 2009 | 03:11 PM
Oldwolf's Avatar
Hi
I forgot to say that it´s a 455 I have. I live in Sweden so the shipping is expensive from US. The car runs greate with E-heads, but as you probably know, enough isn´t enough. The best thing first is to check the valve size . Are there large valves and good valve guides maybee I port them. Whats the differens between C heads and E heads.
Old Mar 6, 2009 | 05:56 PM
citcapp's Avatar
The C heads have the best stock flow of big block heads but not enough difference from your E heads if they are large valve to make it worth the change
Old Mar 7, 2009 | 04:06 AM
Oldwolf's Avatar
Thank you. I have read that filling the exhaust bypass whith liquid metal is a gode move, but it seems a little complicaded. Is this nessesary if I block the passage at the gasket flange?
Regards
Old Mar 7, 2009 | 04:52 AM
cutlassefi's Avatar
E heads
Filling the exhaust passage has two benefits. First is of course you block heat to the manifold. Second is the increase in scavenging you get cuz you've isolated the passages as well as no longer disrupting their flow. You'll also want to weld the exhaust port on the outside to complete the process. All ports need to be isolated from one another.
Cam - IMO I'm not sure that would be the right cam for you. Given the heads you're using I would get something that favors exhaust duration over intake. You'll need the extra flow capabilities cuz you're using stock heads and exhaust manifold.
Old Mar 7, 2009 | 05:03 AM
If you are using stock exhaust manifolds I wouldn't worry about what heads you run, or filling the exhaust cross over. As long as you aren't running J heads you should be fine. All BBO heads flow fine for a street car. Just make sure they are in good shape.
Old Mar 11, 2009 | 02:34 PM
Oldwolf's Avatar
Thank ypu all for the useful information. As I wrote before, the engine is running fine now. When I lift the heads I decide witch road i´m gona take.
I feels better to use the E-heads.
best regarss to you all.
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
