High pressure oil pump?
Old Sep 3, 2022 | 08:46 AM
rippinbyu's Avatar
It there any advantage to installing a high pressure vs high volume oil pump? My engine builder said high volume could starve engine of oil with stock 5 quart oil pan?
Does anyone produce a high pressure pump?
Thanks,
Chad
Old Sep 3, 2022 | 08:52 AM
rippinbyu's Avatar
Olds performance products has this one...not sure if anyone has used it:
https://oldsperformanceproducts.com/...i-performance/
Old Sep 3, 2022 | 11:13 AM
VC455's Avatar
Barely Registered
Originally Posted by rippinbyu
My engine builder said high volume could starve engine of oil with stock 5 quart oil pan...
Chad,
On Oldsmobiles, the thing that can possible starve the pan is if oil released by the lifters holds up under the valve covers. Oil released in other locations will drain immediately to the pan.
The high-volume pump has the same pressure relief valve setting as the standard pump. There's no extra pressure to force release of extra oil. If the system pressure tries to fall it will maintain the standard pressure and standard release in each location. For example, at idle, where the pressure is generally lowest, the high-volume pump would maintain pressure better. But the volume of oil released will not exceed a standard release rate. At higher engine revs, the pressure relief valve opens to dump the extra oil directly back to the pan--no extra pressure would build.
A high-pressure pump will cause extra oil to be released everywhere, including under the valve covers, which could then starve the pan.
Trust your logic.
Gary
Old Sep 3, 2022 | 11:44 AM
ELY442's Avatar
Thanks,
Chad
Damn, those rumors will never die. I have a Melling high volume oil pump and it does NOT starve the engine oil.
Old Sep 3, 2022 | 05:27 PM
cutlassefi's Avatar
Correct. For those who still want to believe the internet crap, block off the drainbacks in the heads and pour 2qts of oil in each valve cover. Then look to see what that actually looks like. Let us know your findings.
Old Sep 4, 2022 | 02:12 PM
rippinbyu's Avatar
Originally Posted by VC455
Chad,
Trust your logic.
Gary
Thank you for the info Gary...any pumps you'd recommend for the Olds? I saw guy above mentioned Melling...they all built the same?
Old Sep 4, 2022 | 02:23 PM
VC455's Avatar
Barely Registered
You are welcome, Chad.
Yes, Melling is a reputable manufacturer. I have their pump in my Olds. I've not heard about problems with that pump.
Gary
Old Sep 4, 2022 | 02:38 PM
I also replaced my original OEM oil pump w/ a Melling four years ago. Very satisfied w/ its performance.
Old Sep 4, 2022 | 05:53 PM
rippinbyu's Avatar
Gary
Thanks!
Out of curiosity....what RPM is your motor turning at 65 MPH with .5 overdrive?
I saw the lowest the Tremec TKX is .68 which would mean 2259 RPM with 3.91s and 25.7" tires
Old Sep 4, 2022 | 06:12 PM
cutlassefi's Avatar
Gary
Thry had some issues with the machining of the gears, very poor finish. Hopefully that’s been fixed.
Old Sep 4, 2022 | 06:44 PM
VC455's Avatar
Barely Registered
1630 rpm with 746 revs per mile tires (275/60-15)
Old Sep 4, 2022 | 08:18 PM
rippinbyu's Avatar
Thats awesome!!! What kind of gas mileage on the freeway?
Old Sep 5, 2022 | 05:45 PM
bw1339's Avatar
Do the two valve covers even have enough volume to starve the engine if completely full with oil?
Rvsmith5
Mar 9, 2021 04:07 AM
Rocketbrian
Jan 2, 2015 09:45 AM
Ausraven
Feb 10, 2012 05:06 PM
Lawndog
Aug 11, 2011 02:27 AM
68conv455
Dec 26, 2007 07:29 AM
