455 high volume oil pump
Old Dec 23, 2007 | 04:54 PM
68conv455's Avatar
I've read that a high volume pump is bad news for a stock 455. I've got a milodon 7 quart pan and the high volume pump and pick-up that go with it. After reading the horror stories, I figured I would attach the milodon extended pick-up to a stock style pump, and run a high capacity pan without concerns of ever running out of oil.
Today I pulled the old pan and noticed the extended pick-up will not fit a stock style pump.
My question is:
Can I run the milodon high volume pump and 7 quart pan with a near stock '71 455? I don't expect to run the motor above 5000 RPM (5500max) as it is not built to run any higher. My highway cruise RPM will be about 2500RPM.
Thanks.
Old Dec 24, 2007 | 04:34 AM
88 coupe's Avatar
Junior Member
Originally Posted by 68conv455
I've read that a high volume pump is bad news for a stock 455 ........
Do not believe everything you read. Especially on the internet.
All else being equal:
At a given pressure, both pumps will move the same amount of oil. In a performance engine that has wider bearing clearances, more volume is needed, in order to maintain oil pressure, and a "standard" pump might not be up to it.
Short answer: The extra 20% of flow is not used, unless it is needed.
........ Can I run the milodon high volume pump and 7 quart pan with a near stock '71 455? ........
Not a problem. Since you are using "factory" clearances, that comination will work just as well as the factory oiling system.
Make sure there is a minimum ⅜" pickup to pan clearance, and 5 qts in the pan, then call it good.
Norm
Old Dec 25, 2007 | 04:35 PM
GoodOldsGuy's Avatar
442=A perfect 10
[quote=88 coupe;21926]Do not believe everything you read. Especially on the internet.
Depending on how you are using your application, slight
restriction of oil to the top end might be in order otherwise you are good to go!
Regards,
Fred
Old Dec 26, 2007 | 07:29 AM
88 coupe's Avatar
Junior Member
Originally Posted by GoodOldsGuy
Originally Posted by 88 coupe
........ Since you are using "factory" clearances, that comination will work just as well as the factory oiling system.
Depending on how you are using your application ........
Following is from his opening post:
I've read that a high volume pump is bad news for a stock 455 ........ ........ milodon high volume pump and 7 quart pan ........
It's a stock engine. He has already spent more cash, than he needed to.
........ slight restriction of oil to the top end might be in order ........
Not needed. If he was interested in overkill, restricted pushrods would have been a better choice than his deep pan.
Norm
davebw31
Jul 14, 2013 05:02 PM
Sampson
Apr 4, 2013 09:47 AM
Redog
Oct 8, 2010 02:57 PM
86pontiac
Feb 17, 2010 11:24 AM
Joel n
Jan 12, 2007 03:34 PM
