HEI in a 68 442
HEI in a 68 442
Has anyone installed an HEI distributor in a 68 442? Are there any clearance issues? I am ready to purchase a distibutor for my motor, and would like to install an HEI setup, but I heard there might be clearance issues. Any suggestions? Should I stick withstock distibutor?
With some older after market 4 bbl intakes there can be a clearance issue there is a hump on the back of the intake that will not let it a hei fit on my original Oldsmobile 4 bbl intake mine works fine.
If you have any clearance problems you can always install a Pertronix conversion. They work great. I don't think I have ever heard of anybody haviing any problems with them. Then if you are purist, nobody can tell since it uses your original distributor.
joepenoso
June 4th, 2014 01:56 PM
