HEI in a 68 442
Old Aug 8, 2009 | 08:17 PM
ctrain22's Avatar
HEI in a 68 442
Has anyone installed an HEI distributor in a 68 442? Are there any clearance issues? I am ready to purchase a distibutor for my motor, and would like to install an HEI setup, but I heard there might be clearance issues. Any suggestions? Should I stick withstock distibutor?
Old Aug 9, 2009 | 12:41 AM
72 cutlass455's Avatar
With some older after market 4 bbl intakes there can be a clearance issue there is a hump on the back of the intake that will not let it a hei fit on my original Oldsmobile 4 bbl intake mine works fine.
Old Aug 9, 2009 | 10:06 AM
redoldsman's Avatar
Proud Viet Nam Veteran
If you have any clearance problems you can always install a Pertronix conversion. They work great. I don't think I have ever heard of anybody haviing any problems with them. Then if you are purist, nobody can tell since it uses your original distributor.
Old Aug 9, 2009 | 08:34 PM
ctrain22's Avatar
I am using the stock manifold, so I am hoping I will not have the clearance issues the aftermarket manifolds have (from what I have heard). Would I be safe in saying that?
Old Aug 10, 2009 | 01:00 AM
With the stock manifold you should be fine.
Old Aug 11, 2009 | 12:40 PM
1964f-85's Avatar
converted a stock 72 350 and a 72 442 to a GM HEI with no problems. Don't forget to remove the resistor wire!
Old Aug 11, 2009 | 02:48 PM
My442's Avatar
MAD Enterprises sells a nice HEI comversion kit for small money.
joepenoso
Jun 4, 2014 01:56 PM
Orlando Perez
Jul 10, 2012 12:46 PM
oldscruiser
Feb 15, 2011 12:44 AM
Oldsmobile Jo
May 30, 2010 07:58 AM
viper771
Oct 1, 2009 05:10 PM
