Header tube to oil filter proximity
Old Dec 23, 2007 | 05:06 PM
68conv455's Avatar
I test fit my Thorley headers today and there is about 1/4"-3/8" gap between the header tube and the oil filter. Is this OK? It will spin on and off OK but I'm worried about heat. I was thinking I could possibly run a slightly smaller diameter filter (if an off the shelf one exists), or run a remote filter assembly. I'd prefer to keep the existing set-up. Is it OK to run as-is? Does anyone know of a slightly smaller filter I can run on the stock mounting point? What do you recommend?
Thanks.
Old Dec 23, 2007 | 05:12 PM
csstrux's Avatar
I've got a 68 w headers running about the same clearence. Doesnt seem to be a problem. I don,t believe you will need to downsize your filter. If you are concerned you could opt for a remote mount, but there seems to be enough air flow running the filter in the stock configuration.
Old Dec 23, 2007 | 05:14 PM
kevinkpk's Avatar
Thanks.
My advice is to never skip on filtrartion for the engine. Don't go to an filter just to save space, you should realize the micron rating, anti-flow back valve, alot of things take into play with just an oil filter, but it is crucial to the engine.
Headers are fine, my last set was on a 64 Impala SS 350, but either reroute your filter, or have other considerations as believe it or not, oil filtration is of most importance.
Old Dec 23, 2007 | 05:24 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I would imagine that any oil filter nowadays would be a better rating than a 1968 one.
Old Dec 23, 2007 | 05:31 PM
kevinkpk's Avatar
Well, maybe a Fram back then, but not now (in my opinion) just some considerations.
Old Dec 24, 2007 | 06:07 AM
88 coupe's Avatar
Junior Member
........ Is this OK? ........
Not only OK, it's normal.
Norm
Old Dec 24, 2007 | 11:44 AM
Redog's Avatar
Good to know.
I think I found a set of headers for the Delta and that PF-24 oil filter is huge, a lot of a lot fatter than that PF-61 the 307 had.
As long as they aren't touching I would think it would be fine. HA I had the "cap" fall off the stock manifold and shooting a flames out the hole right nect to the oil filter and the car's still fine
Old Dec 25, 2007 | 04:24 PM
GoodOldsGuy's Avatar
442=A perfect 10
Thanks.
Don't know if you already have a shorty on there...it won't help diameter wise...a remote location would work to keep the oil filter away from the engine heat. They can be had through Jegs or Summit. Good luck with your fix.
Regards,
GOG
hawks70
Jun 24, 2013 09:30 PM
defiant1
Aug 26, 2011 09:45 AM
