proximity of lines to headers
Old Jun 18, 2013 | 03:47 PM
hawks70's Avatar
How close is too close to the headers where brake lines and trans cooler lines are concerned? Any thoughts?
Old Jun 18, 2013 | 04:54 PM
I like to keep a couple of inches of space between at a minimum. The more the better though.
Old Jun 18, 2013 | 05:15 PM
hawks70's Avatar
OK. I think my cooler lines are fine but considering re routing right front brake line because it comes real close at frame on both sides. About a half inch or so.
Old Jun 18, 2013 | 06:05 PM
Sometimes you can flip or relocate clips and bend them out of the way. Most have issues with the proportioning valve.
Old Jun 19, 2013 | 09:42 AM
hawks70's Avatar
Took care of valve already. Its bolted on way up high and out of the way so that's OK.looks like I should have enough line to flip it to the front side so that's good. Today I'm charging the battery a bit and crank her up and let her run and get the carb dialed in.
Old Jun 24, 2013 | 09:30 PM
jfb's Avatar
jfb
I have the same issue and i carefuly with all fingers gently pulled the line higher then the pipe for clearance and use all fingers and both hands.
Bobac455
Brakes/Hydraulic Systems
May 14, 2012 07:52 AM
Wyze
Mar 18, 2012 01:59 PM
68conv455
Dec 25, 2007 04:24 PM
<mr.stew@netzero.net>
Oct 18, 2004 11:20 AM
<zeke>
Aug 7, 2004 09:09 PM
