Gas filter inside carb plus a large inline gas filter just before the carb
Old July 14th, 2013, 07:18 AM
joepenoso's Avatar
Question Gas filter inside carb plus a large inline gas filter just before the carb
Gas filter inside carb plus a large inline gas filter just before the carb...............................Could that cause overheating, on the highway??
joepenoso
joepenoso is offline
Old July 14th, 2013, 07:50 AM
Erinyes's Avatar
I used to run that setup on a 71 GMC for years. Never a problem.
Erinyes is offline
Old July 14th, 2013, 07:56 AM
It will not cause overheating, however you don't need both.
oldcutlass is offline
Old July 14th, 2013, 03:48 PM
joepenoso's Avatar
Exclamation
I replaced radiator, water pump, head gasket, heads, head bolts, still not ready to fire it up ..................hoping I solved high speed overheating and coolant exhaust contamination.
joepenoso
Old July 19th, 2013, 12:44 PM
liquidpower's Avatar
i have an inline befor pump and then the one in the carb
liquidpower is offline
phillipm
June 23rd, 2015 12:29 PM
DanOldsMan
February 10th, 2014 07:18 AM
johns59super88
June 2nd, 2012 03:11 PM
Redog
November 13th, 2010 10:07 AM
Eddiejr
October 23rd, 2007 04:53 AM
Quick Reply: Gas filter inside carb plus a large inline gas filter just before the carb
