Easy ? RE: Front Seal
Old Nov 15, 2006 | 11:38 AM
kcompton's Avatar
Hi all, I'm new to Olds Big Blocks, and have a timing cover to balancer seal to replace. Is it necessary to remove the timing cover to do this job, or can I just remove the balancer to get to it?
Thanks,
Ken
Old Nov 15, 2006 | 02:07 PM
Oldsguy's Avatar
Past Administrator
That seal is pressed in, I doubt you will be able to remove it without removing the cover, or install the new one for that matter. That is something the Chevy guys always rib me about (only thing??) the cover isn't two piece like theirs so that job neccesitates the full removal of the cover, and the water pump. But you are already halfway there by the time you get the balancer off anyways so....
Old Nov 15, 2006 | 02:26 PM
kcompton's Avatar
Really? That's too bad... I was told that it could be done without removing the cover. I haven't had alot of experience with the bottom ends of engines. So there's no way for me to get that seal out and the new one in without a press?
Thanks.
Old Nov 16, 2006 | 04:42 AM
Oldsguy's Avatar
Past Administrator
Well, you might be able to pry the old one out from the font side and the hammer a new one in. Nothing is impossible, I have just never done it that way. Give it a try and let us know how it turns out.
Thuffner3
Dec 11, 2007 07:38 PM
big-al-D-88
30
Dec 2, 2007 01:09 AM
1BAD68"S"
Nov 9, 2006 04:30 AM
RussTad
Sep 19, 2006 02:16 PM
Sixoh
Aug 8, 2006 05:11 AM
