Double throttle return spring?
Old Jul 29, 2025 | 08:13 PM
eggydrummer's Avatar
Came across a YouTube short video about carburetors, and the guy mentioned using a double return spring in case one fails. Is this necessary? Is this one of those overthinking things? My 61 Olds 98 has but a single return spring. Looks to be in good shape because I replaced it years ago. The original didn’t have that “springiness” to it anymore.
Anyway, just thinking safety precautions here. Thoughts?
Old Jul 29, 2025 | 08:35 PM
Dual springs are OK as long as they are “soft”’ enough so you can easily operate the throttle. Too stiff and it can make the throttle hard to operate.
I know nothing about your era carb, but mine has a built-in return spring on the throttle shaft, so the single external spring makes it a dual spring configuration.
Old Jul 29, 2025 | 09:01 PM
OLDSter Ralph's Avatar
Don't believe everything you see on YouTube. If it bothers you, replace the spring every10-20 years or so.
Old Jul 30, 2025 | 02:31 AM
fleming442's Avatar
I believe it's an NHRA rule. I wouldn't sweat it. There are return springs on the throttle shaft.
Old Jul 30, 2025 | 03:10 AM
66_Jetstar's Avatar
Yep, need two springs to run at the track.
Old Jul 30, 2025 | 05:35 AM
CutlassMarc's Avatar
YUP. you need two springs.
It isn't a bad Idea, less likely to have the throttle hang open with 2.
Old Jul 30, 2025 | 06:00 AM
69 Hurst's Avatar
Olds Fanatic
I've always run two springs.
Old Jul 30, 2025 | 06:05 AM
Dual springs have been a federal requirement since the early 1970s. Yes, the factory ones are quite soft individually.
Old Jul 30, 2025 | 06:48 AM
Well, I'll be dipped in sugar. Thank you Joe P and Fleming. I learned something new.
Old Jul 30, 2025 | 08:20 AM
70sgeek's Avatar
'72 Cutlass ragtop
Years ago on my '68 Charger the throttle spring snapped while I was on a highway road trip - instantly propelling me from 50+mph to 80+ before I was able to get the car into neutral and pull the gas pedal up from the floor, all while positioning the car over towards the shoulder for an eventual stop.
Luckily it snapped in a place where it left me enough to stretch a remaining section of it back in place so that I could get off the highway and find a local auto parts store for a replacement
At the time I'd thought I had an spare spring in the glove box but of course, nope....
So yeah, dual springs not a bad thing....
Old Jul 30, 2025 | 08:22 AM
old80cs's Avatar
Dual springs on my Edelbrock 1406, no internal spring so two external springs for safety sake.
Old Jul 30, 2025 | 10:26 AM
Sugar Bear's Avatar
Did the dual springs appear at the same time throttle linkage was replaced with cable in '68?
Adding a spring to a single spring set-up is similar to changing from a single to dual reservoir MC in that, it isn't a problem until...
Yes, do it.
Old Jul 30, 2025 | 06:45 PM
Yes, do it.
No, it was 1974.
Old Jul 30, 2025 | 07:56 PM
gs72's Avatar
72Cutlass S
I have two on mine. One facing forward and one facing backwards. That being said the Feds have yet to show up at my door to check.
Old Jul 31, 2025 | 08:31 AM
So, all in all, maybe not a bad idea? A couple pics of the setup on my Rochester 4GC carb with the spring.
Falkon
Feb 28, 2023 06:33 PM
Will22
Jan 15, 2019 05:44 AM
spaceman_spiff
Jul 17, 2017 08:02 AM
defiant1
May 12, 2011 10:32 AM
1969w3155
May 26, 2010 12:00 PM
