Could my block be cracked?
Old Sep 17, 2023 | 10:57 AM
I went to start my 71 today. It starts effortlessly every time (as long as the distributor is hooked up).
It ran for about 5 minutes and started leaking at the thermostat bypass. It currently doesn't have a thermostat installed. I quickly topped off the radiator after starting the car and installed a new radiator cap. The upper radiator hose is rock hard.
I've done 2 compression tests since I put the heads on the engine (both with the same gauge). It has good compression. The water pump is a known "good" pump off of my other 455. The radiator is a new parts store cheapie. Both of the radiator hoses are new.
I suppose the hose clamps for the thermostat bypass could have been loose and caused the leak. I could always go out and start the engine and let it run unit it blows a radiator hose or cap.
A cracked block would be IDed with a cylinder leak down test, right? I would get bubbles/leakage in my radiator or crankcase if my block is cracked? Can you get poor leak down test results with good compression?
​​​​​​Sort of at my wits end. Might be time to swap in my spare 455 since Oldsguy doesn't seem to want it anyways.
Old Sep 17, 2023 | 11:14 AM
Try tightening the clamp, it could also be a small leak in the hose itself.
Old Sep 17, 2023 | 12:53 PM
Oldsguy's Avatar
Past Administrator
Is there a way to pressurize the system without running the engine and getting it hot? maybe with compressed air? Then you could listen as well as look for a leak. Just speculating.
Old Sep 17, 2023 | 01:27 PM
I can get a coolant system pressure tester.
As I mentioned to Oldsguy on the phone, it's been 3 or 4 hours since I ran the 71 and the upper radiator hose is still hard. It's not even warm anymore. I think whatever problem the 455 in my 71 had that caused the head gasket to blow and the parts store cheapie radiator to exploded is still present.
I cleaned the deck and chased the head bolt holes when I had the heads machined. There were no cracks present to the naked eye. The machinist magnafluxed the heads and cut new valve seats and faces.
Old Sep 17, 2023 | 01:47 PM
It takes a while for the system to lose pressure. What you're seeing are good things. Hoses tend to leak when the temps get cooler out and a simple hose clamp tightening usually fixes it.
Old Sep 17, 2023 | 01:57 PM
Jesse - Before you get too far into it...buy one of these kits and have at it. Fast, inexpensive & they work. Suggestion - after you've ran the car for 12-15 minutes, use the flashlight in a very dark garage as the dye shows up much better. Me, I'd perform this test first. $16.00
Get a small bottle of Radiator UV dye ($8.99). Radiator UV dye is miscible in coolant i.e. not same as oil UV dye. Take the guess work out, find the leak.
A/C Pro Leak Detector UV Pen Light/UV Glasses
Old Sep 17, 2023 | 03:05 PM
Sugar Bear's Avatar
If there isn't coolant in the oil and there isn't white smoke out of the tailpipe the block and heads are likely not cracked. A leak down test may not show a crack if the block is cool.
A test for exhaust gases in the coolant would provide the answer.
Old Sep 17, 2023 | 03:51 PM
This is perplexing to me. If you have combustion pressures going into your cooling system, then you would think the pressure would bleed off soon after the engine is shut off... Right?? If there is a bad head gasket/ cracked head/ cracked block wouldn't the crack/leak allow the compression to go into coolant when running and then go right back thru the crack/leak and pressure go away when shut off as it dissipates from where it came??? But you say the pressure is still there after engine has been shut off and cooled down after 3 or 4 hours??? I don't get it...?? You say the heads were magnafluxed?? So they don't have any cracks ( if you can trust the magnafluxer) . So it has to be gaskets or block. Can you get the pressure tester and put on radiator, start engine and watch gauge. If it goes up immediately after starting, then yes combustion is going into coolant. So then shut off engine and see if pressure starts going down. It should. Good luck .
Old Sep 17, 2023 | 05:19 PM
I agree. The local auto parts store will rent a combustion gas test kit, all you buy is the test fluid for under $10. I did this on my Jeep and it was very simple.
Old Sep 18, 2023 | 03:02 AM
WTF, I took the radiator cap off this morning (15+ hours later) and there was still pressure in the radiator. Enough to spit coolant all over my hand and onto the ground. Should have taken video of it. 🤯
I have a combustion gas tester I bought when the head gaskets "BLEW" on the 5.4l Triton V8 I owned. MAW give it a try.
Old Sep 18, 2023 | 03:52 AM
Wow, Jesse that is really strange, like a one way passage that lets compression in cooling system then holds it- Not impossible I guess but very strange. What else could it be? I think you should test for the combustion gases also.
Old Sep 18, 2023 | 02:48 PM
Makes me think head gasket. When the air/fuel charge ignites, it generates a lot of pressure (150-200 psi) that could push past the head gasket, then the gasket seals well enough so not all of the pressure flows back into the cylinder. Kinda like a one way check valve.
Old Sep 18, 2023 | 08:10 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Were the heads tested for cracks? My 5.9 in my Dakota blew head gaskets. I replaced them, about 100 miles later, rock hard upper hose and violently blowing coolant out of the rad cap. Replaced the heads, Dodge Magnum heads have known issues. No more violent coolant escape!
Old Sep 19, 2023 | 03:29 AM
In this thread posts # 47 & 56 I give compression test results AFTER having the heads rebuilt and installing them. Both times I had good results.
https://classicoldsmobile.com/forums...2/#post1497576
I agree that the symptoms seem like a blown head gasket again. I have a combustion gas chemical tester I'm going to try. I suppose if that indicates combustion gasses in the coolant I'll conduct a cylinder leak down test or buy a new compression gauge. The one I have now I bought when I owned my 64 98 before Momma and I got married.
Old Sep 19, 2023 | 05:29 AM
You can have good compression checks cuz your compression is around 100 psi or so. But then you add gasoline mixture and spark it and it explodes- I'm sure way more than 150 psi. I think Ken is prolly right. Keep at it Jesse, you'll get it.
Old Sep 19, 2023 | 09:06 AM
Oldsguy's Avatar
Past Administrator
WTF, I took the radiator cap off this morning (15+ hours later) and there was still pressure in the radiator. Enough to spit coolant all over my hand and onto the ground. Should have taken video of it. 🤯...
This is confusing, how/what can keep pressure in the coolant jacket/hoses/radiator after that long of a period. It seems it would bleed out someplace.
Old Sep 19, 2023 | 05:15 PM
FStanley's Avatar
1. you can rent a pressure tester from Autozone... you buy it 1st, then return I think within a few days and you get your money back. I
https://www.autozone.com/loan-a-tool...ressure-tester
2. I would put a thermostat it. it is needed to regulate the temp..
3. You could rent a leak tester using UV dye
https://www.autozone.com/loan-a-tool...-leak-tool-kit
4. also blown gasket tester if you need it
https://www.autozone.com/loan-a-tool...-gasket-tester
Old Sep 20, 2023 | 06:36 PM
No combustion gases present in the water jacket.
The engine idled for 20 minutes today and the upper radiator hose only ever reached 140* F. I set the electric fan to HI. Apparently, the LO relay for my electric fan is faulty ( cheap imported electronics).
This weekend I plan on starting & tuning the engine and taking the 71 for a test drive.
Old Sep 20, 2023 | 09:12 PM
You may have a messed up radiator cap.
Old Sep 21, 2023 | 03:35 AM
Well that's good news, Maybe no problem after all. Good deal.
Old Sep 21, 2023 | 04:33 AM
Definitely a relief.
I'll let everyone know how the test drive goes this weekend.
oldsrush
Jun 30, 2023 07:02 AM
classicmuscle442
Jul 4, 2019 09:04 AM
Flye
Apr 4, 2013 06:29 PM
case2273
Jun 14, 2008 04:02 PM
Sixoh
Feb 17, 2007 06:41 AM
