Composite Distributor Gear
I removed my distributor today to check my "bronze" gear. It was showing quite a bit of wear, (almost 2 summers approx 700 miles). I put in a BOP engineering composite gear. I was wondering if anyone has any first hand, long term use experience to share.
They’re actually a composite, typically made from as many as three materials, one of them being bronze.
No one has been able to explain what BOP's "composite" is. Is it plastic, metal or some non ferrous material.
Thank you in advance.
I had the same, short-life, experience with a bronze gear. Mine was AMPCO 45, an alloy of copper, aluminum and nickel--supposedly one of the longer-wearing "yellow-metal" gears.
After some research, I bought and installed the plastic gear from BOP. I haven't run it yet to be able to report on its life. But I did find that it is composed of PEEK (Polyether ether ketone) plastic with about 30% carbon fiber added. My younger machinist friends recognized the PEEK name and told me it has amazing properties of durability.
I don't mind spending good money if the product is good.
X 2 Color makes little difference if you can't provide chemical composition. There are several "brass" colored materials that would outwear the camshaft teeth. I can tell you I have machined AMS 4640, Ampco 19 and Ampco 21. Unless you have tried to machine or drill a hole through, you are guessing.
Your information on PEEK is interesting. Thats the most informational description I have seen. Carbon fiber is also interesting to know. Thank you.
Ralph, I was referring to brand labels- Comp and Allstar, specifically. I was getting 491 gears and having them milled to 500. They all failed prematurely, despite the machinist remarking how hard they were.
Granted, I am not current on the latest "plastics".
Pardon my ignorance on bronze gears but 700 miles doesn't seem like much to me.. Why is this type of material needed??
My '79 350 stock distributor gear has 220K on it and still looks good to me and even no noticeable play.. I'm on a second engine..
Fred
Fred
Some aftermarket cams (typically roller cams) have gears of material that results in wear of both the cam and distributor gears.
The traditional hot-rod way of combatting this is to use a sacrificial copper-alloy gear, developed about 60 years ago. These need to be monitored for wear and replaced periodically.
Newer types of distributor gears have been developed that can take the place of the copper-alloy gears without causing any abmormal wear of either gear.
Your OEM cam and gear combination is good for many miles and years without your needing to give it a thought.
42-413-11. It's a mild cam, good for street. With the 400 g I strengthened the connecting rods, (eagle H rods, ARP fasteners sealed power pistons). I used Harland Sharpe pedistal rockers). I didn't
want too rude a cam. My next engine I'll use a rude, obnoxious, spitting cam. But that will be a Rocket Racing 4 bolt main block.
You never should have run a brass dizzy gear on the street. I know years ago Comp recommended a brass gear for all their Olds hyd rollers , even street use, that was wrong. You should have run a melonized or composite gear. Composite gears like the one you have now work will all cam materials
the last digits denote cam core material. anything -9 thru -16 are billet steel. So yours is in the steel group. 5150, 5160, 8620, 8650 or 9310 and or variations of heat treating of those. -17 is tool steel. -2 thru -5 are cast iron. -6 is the old hyd roller cores which also needed specific dizzy gears. -8 is austempered ductile iron, usually for flat tappets that will be nitrided.
matt69olds
May 29, 2025 12:50 PM
