chevy 454
chevy 454
i was wondering are there any special motor mounts that i woulld need to install a 454 in 72 cutlass convertible. also is it a good idea to do this? its going to be a total rebuild with the stroker crank
The people at http://www.chevelles.com/forums/ will be happy to answer all your questions about Chev engines.
Norm
Norm
I don't think it would be a good idea. Chevy engines need 4 bolt mains because the blocks are cast out of hardened toothpaste (you know, like the toothpaste on the edge of the sink in the evening). It isn't a good idea to use them. They usualy blow headgaskets at about 4:1 compression. The hi compression engines are 5:1.
chevy 454
thanks how would i build a kick @ss 455 or the 350 rockets that already installed i really want a stroker and would the 400 turbo transmission from chevy work thanks or the
Last edited by 72droptop; December 20th, 2007 at 12:00 PM. Reason: left something out
Well, there is alot of advice here on how to build a hi performance 455 or 350. If you build an Olds engine you probably won't build a stroker. That is mostly a Chevy phenomenon. Why would you want to build a stroker when you can buy a 455 which already has a long stroke and makes more torque than you can shake a stick at? BTW, a Chevy TH 400 will NOT bolt up to an Oldsmobile engine.
The 400 tranny will work, but you'll need an adapter plate to hook it up to the motor. BPO have a differnet bolt pattern than Chevys
Get a good 350 or 455 (350, 395558 "2" block from 68 to 72 cast iron and soild mains, maybe somebody else can shead light on the best 455) and basicly a good cam, lifters, decent manifold, decent ign, good heads (stock 5 or 7a for small blocks and C for the big block) and a set of headers and you'll have a pretty decent streetalbe motor. Just be sure to get good cooling, and a deeper oil pan would be a good idea too!
found a big block. the casting numbers are 396021F out of a 1975 olds. is ths a good block to rebuild
Use the 455 engine, mild cam, headers, Torker intake coupled with a Turbo 400 trans 12 bolt Olds with 3:42 gear and you will have a fast and reliable street machine with gobs of torque. Torque is what moves you out quick!
"There is no substitute for cubic inches."
Regards,
Fred
Regards,
Fred
DennisG.
April 2nd, 2012 12:50 PM
shaks 442 clone
May 31st, 2007 08:42 AM
