chevy 454
Old Dec 19, 2007 | 08:55 PM
72droptop's Avatar
Question chevy 454
i was wondering are there any special motor mounts that i woulld need to install a 454 in 72 cutlass convertible. also is it a good idea to do this? its going to be a total rebuild with the stroker crank
Old Dec 20, 2007 | 04:25 AM
Oldsguy's Avatar
Past Administrator
I don't think it would be a good idea, the Cutlass deserves an Olds engine.
and I don't know anything about chevy engines except they are orange.
Old Dec 20, 2007 | 04:41 AM
88 coupe's Avatar
Junior Member
The people at http://www.chevelles.com/forums/ will be happy to answer all your questions about Chev engines.
Norm
Old Dec 20, 2007 | 05:12 AM
I don't think it would be a good idea. Chevy engines need 4 bolt mains because the blocks are cast out of hardened toothpaste (you know, like the toothpaste on the edge of the sink in the evening). It isn't a good idea to use them. They usualy blow headgaskets at about 4:1 compression. The hi compression engines are 5:1.
Old Dec 20, 2007 | 11:56 AM
72droptop's Avatar
Thumbs up chevy 454
thanks how would i build a kick @ss 455 or the 350 rockets that already installed i really want a stroker and would the 400 turbo transmission from chevy work thanks or the
Old Dec 20, 2007 | 01:42 PM
Well, there is alot of advice here on how to build a hi performance 455 or 350. If you build an Olds engine you probably won't build a stroker. That is mostly a Chevy phenomenon. Why would you want to build a stroker when you can buy a 455 which already has a long stroke and makes more torque than you can shake a stick at? BTW, a Chevy TH 400 will NOT bolt up to an Oldsmobile engine.
Old Dec 20, 2007 | 01:46 PM
Redog's Avatar
The 400 tranny will work, but you'll need an adapter plate to hook it up to the motor. BPO have a differnet bolt pattern than Chevys
Get a good 350 or 455 (350, 395558 "2" block from 68 to 72 cast iron and soild mains, maybe somebody else can shead light on the best 455) and basicly a good cam, lifters, decent manifold, decent ign, good heads (stock 5 or 7a for small blocks and C for the big block) and a set of headers and you'll have a pretty decent streetalbe motor. Just be sure to get good cooling, and a deeper oil pan would be a good idea too!
Old Dec 21, 2007 | 11:12 AM
72droptop's Avatar
thanks for the info. it's not cool to be the dumb one, but with guys like you all, that got my back, it's kinda Ok.
Old Dec 21, 2007 | 11:15 AM
Oldsguy's Avatar
Past Administrator
No, I wouldn't say the dumb one. It is all relative, there is always someone, someplace that knows more than me, or you, or (fill in the blank). We just like our Oldsmobiles.
Old Dec 21, 2007 | 11:25 AM
72droptop's Avatar
found a big block. the casting numbers are 396021F out of a 1975 olds. is ths a good block to rebuild
Old Dec 21, 2007 | 12:14 PM
88 coupe's Avatar
Junior Member
Originally Posted by 72droptop
........ is this a good block to rebuild?
They are all good.
Norm
Old Dec 22, 2007 | 09:40 PM
z11375ss's Avatar
Senior Moment Member
I've had both engines and liked the Olds better. Stump pulling torque opposed to needing to rev high to produce power. Small blocks are different though. I like my 71 LT1 Vette, it screams!
Old Dec 23, 2007 | 04:52 AM
66 Holiday 461's Avatar
Rocketman
You are only the dumb one if you stick a cheby in your Olds. The car would never recover from the shame.
Old Dec 23, 2007 | 05:56 AM
Yeah, I think it would be a bad case of automotive suicide. The car would probably just give up.
Old Dec 25, 2007 | 05:19 PM
GoodOldsGuy's Avatar
442=A perfect 10
Use the 455 engine, mild cam, headers, Torker intake coupled with a Turbo 400 trans 12 bolt Olds with 3:42 gear and you will have a fast and reliable street machine with gobs of torque. Torque is what moves you out quick!
"There is no substitute for cubic inches."
Regards,
Fred
DennisG.
Apr 2, 2012 12:50 PM
dan1s
May 19, 2008 05:52 AM
shaks 442 clone
May 31, 2007 08:42 AM
dustyk70
Mar 7, 2007 07:21 PM
grandmas73rocket
Nov 23, 2004 04:51 AM
