Cam. bearing question
Old Oct 8, 2013 | 05:42 PM
foo's Avatar
foo
Is there a ring bearing that goes between the cam and the block, just in front of the first bearing. Or will it ride on the block itself or will the distributor hold it from doing that?
Old Oct 8, 2013 | 06:05 PM
Oldsmaniac's Avatar
It rides on bearings throughout. It should never ride on the block.
Old Oct 8, 2013 | 06:07 PM
foo's Avatar
foo
Im not actually talking about the 5 cam bearings, just the very front of the block bearing hole.
Old Oct 8, 2013 | 06:49 PM
Not sure what you mean.
Old Oct 8, 2013 | 07:02 PM
foo's Avatar
foo
Sorry, hope I explain this little better, what is keeping the cam from riding into the block further and having the end that the timing sprocket connects to, hit the block
~Note for a 455
Old Oct 8, 2013 | 07:48 PM
My recollection is that there is a machined surface around the front bearing location that the back of the central portion of the sprocket bears lightly against.
I must admit that I never really thought about it.
There is no specific thrust bearing.
Old Oct 8, 2013 | 07:53 PM
coppercutlass's Avatar
Chevy budget Olds powered
Are you talking about a torrignton style bearing to prevent wear on the block ? I have taken apart many stockers and never seen anuthing between the cam and block surface., although I think some opt to machine the block to hold a bearing or thrust washer etc.
Old Oct 9, 2013 | 01:22 AM
foo's Avatar
foo
That's the one.
That answers my question thank you guys.
tru-blue 442
Mar 30, 2022 09:53 AM
steverw
Jul 22, 2013 01:06 PM
archerbob
Sep 12, 2011 05:33 PM
Flye
Drivetrain/Differentials
Jul 30, 2009 10:24 AM
442 Guatemala
Mar 28, 2009 02:07 PM
