68 442 Coolant leak!
Old February 16th, 2015 | 10:32 AM
  #41
442craig's Avatar
Well after all that I ended up buying it form Jegs. No shipping fee or sales tax
made the difference!
Now off to find an impact wrench!
Thanks guys,
Craig
Old February 16th, 2015 | 03:28 PM
  #42
442craig's Avatar
Pulled apart!
Well,
Got everything apart. I borrowed a puller and installer from Pep Boys and bought a 1/4" x 1" x 3' piece of steel and drilled 2 holes to mount to the balancer. I used the handle off my floor jack as a persuader and loosened the bolt. The balancer came off easy. I loosened the bolts on the pan enough to pop the cover off. I have to wait a week for the cover but it was a successful day in Olds land!
Thanks for everyones advise, I couldn't have done it without you all!
Craig
Old February 16th, 2015 | 03:40 PM
  #43
Jeeze, I can't imagine why it leaked...
Old February 16th, 2015 | 03:41 PM
  #44
By the way, be sure to check the balancer for scoring where the seal rides on it. You can get the repair sleeve to fix it to prevent chewing up your new front seal.
Old February 16th, 2015 | 05:47 PM
  #45
442craig's Avatar
i'm amazed it didn't leak more!
The balancer looks good, should be an easy assembly. (Now I just jinxed myself!)
Craig
Old February 17th, 2015 | 01:46 PM
  #46
Stevec's Avatar
How's the timing chain while your in there? Those things are notorious for stretching and the nylon gears wear considerably with age.
Old February 17th, 2015 | 02:22 PM
  #47
442craig's Avatar
This is a brand new engine, just didn't replace the timing cover. The chain is brand new.
Craig
Old February 17th, 2015 | 02:51 PM
  #48
Stevec's Avatar
Gotcha...
Old February 17th, 2015 | 05:16 PM
  #49
allyolds68's Avatar
Your engine builder didn't re-use that, did he?
Did the balancer come off without using the puller?
Old February 17th, 2015 | 06:25 PM
  #50
442craig's Avatar
Yep
I used the puller I borrowed from Pep Boys. The bolt was the hard part!
65topless
May 6th, 2013 06:15 PM
mbrae5
September 11th, 2012 12:23 PM
olds88royalvert
September 10th, 2009 05:03 PM
cutlass47
Tech Editor's Desk
October 7th, 2008 06:29 AM
Diabolus
July 23rd, 2004 04:35 AM
Quick Reply: 68 442 Coolant leak!
