66 L-69 Tri-Carb Fuel Filter Real or Not
Old Feb 14, 2012 | 09:55 PM
Chuck_66's Avatar
I am interested in a 66 Tri-Carb fuel filter but, I do not know what to look for can someone please post a photo of one.
Old Feb 15, 2012 | 08:12 AM
Run to Rund's Avatar
I think Mike Siedlik is reproducing them. I can take photos after the foot of snow clears away from the garage. Original stuff will be very rare and expensive these days.
Old Feb 15, 2012 | 11:04 PM
Chuck_66's Avatar
I appreciate it but you can take your time I have been looking off and on for the past 5 months and I can not even find a photo. I purchased a tri-carb setup that has a glass filter when it arrives I will post a few photos. Do you have a tri-carb installed in your car? The original glass filter is a nice to have but what I really need is the bellcrank and carburetor rod. Do you know if anyone is reproducing them?
Old Feb 16, 2012 | 04:45 AM
wmachine's Avatar
Trying to remember member
I believe these are correct.
Old Feb 16, 2012 | 06:10 AM
wmachine's Avatar
I just posted factory photos of the Tri-Carb on Wild About Cars.
http://wildaboutcarsonline.com/cgi-b...=9990406644564
Old Feb 16, 2012 | 09:09 AM
Here are photos of Tri Carb linkage and fuel filter.
Old Feb 16, 2012 | 06:17 PM
66trakpak's Avatar
i believe a guy in california was repoing the throttle rod and bell crank. his name is pat rogers. dont have any contact info unfortunately.
Old Feb 16, 2012 | 06:18 PM
66trakpak's Avatar
hey kurt, any of those filters for sale?
Old Feb 16, 2012 | 06:27 PM
wmachine's Avatar
Not mine, just part of my picture archive.
Old Feb 16, 2012 | 07:39 PM
Chuck_66's Avatar
Thank you all very much for the technical assistance I truly appreciate it. Run to Rund your bellcrank can you measure the center to center distance from the carburetor rod hole to the hole just below it and in one of the photos you show two fuel filters what are they from. I believe the lower section of the bellcrank is the same as the 4 barrel. If I can't find it I will have someone make one or two bellcranks as I work in a machine shop. Wmachine that site you posted is great I spent several hours last night on it.
Old Feb 17, 2012 | 03:33 AM
jrzybob442's Avatar
45 yrs of Olds Nuttiness
If you co to Wild About Cars "Factory Publications Section" http://wildaboutcarsonline.com/cgi-b...=9900334159517
And use the "search" button (red, in the upper left) and enter "tri-carb", you will get the followint results:
1965 Marketing Bulletin
(2) instances of Factory Photos
Service Guild Training Guide for the Tricarb, which has plenty of photos
1966 OAI Install
Tri-Carb Assembly and Parts List
Tri-Carb Adjustments
Old Feb 20, 2012 | 07:06 PM
Those filters and lines are for Tri Carb engines. The L bracket for Tri Carb cars is longer from carb rod to pivot (2") than Quadrajet cars.
Old Feb 20, 2012 | 09:32 PM
Chuck_66's Avatar
Thank you Run to Rund I will take my 4 barrel bellcrank and have someone make one that is two inches longer maybe I should have him make a few.
Old Feb 21, 2012 | 09:05 AM
The distance will be 2" not 4 bbl plus 2". I don't have any 4 barrel L brackets for comparison.
Old Feb 22, 2012 | 01:33 AM
Chuck_66's Avatar
Thanks Run to Rund. I received the Tri-Carb setup here are some photos.
Old Mar 16, 2013 | 08:36 PM
Octania's Avatar
Chuck 66
First off, your GBFF [glass bowl fuel filter] is close, and adequate, but the fine details differ from the AC422 as seen above. This will of course cause great wailing and gnashing of teeth if you have the car judged. Otherwise, it'll be fine. Note, on the real one, the large diameter and finely knurled bail ****. Also, the mounting boss is round at the bolt, and a large hex under that, on the real one. The "close" one has sort of a square boss with corner protrusions.
The L69 intake looks great, carbs look pretty well done, but I would be suspicious of the work ddone by a person who uses teflon tape on inverted flare fuel fitting.
PS if you ran across any extra CARBS in your search, I got an intake that needs everything else.
I redid a '66 a few yrs ago, we had to lengthen the bellcrank arm; I did this by welding on the extra length. For the rod, I welded one up out of two more common units, based on a drawing from a friend out west.
RenderPit
Ninety-Eight
Aug 6, 2015 04:55 PM
oldjunkster
Mar 1, 2014 05:58 PM
Mr Shifty Sidney
Dec 3, 2013 05:47 PM
RandyS
Oct 4, 2012 12:36 PM
