455 shortblock back from machine shop (head gasket)
Old Jul 19, 2023 | 06:20 AM
rfpowerdude's Avatar
I went and picked up my freshly machined and assembled shortblock from Mark R.'s place on Saturday. I need to select a head gasket out of all the ones available.
Any suggestions on which one I should get? FelPro? MrGasket? Mahle? Cometic? I plan to have it all assembled by the 29th and will take it back over to Mark's to make some pulls on his dyno.
Old Jul 19, 2023 | 06:27 AM
fleming442's Avatar
I run Cometics
Old Jul 19, 2023 | 06:58 AM
I just reassembled my 455 with FelPro gaskets.
Old Jul 19, 2023 | 07:11 AM
quizkid32's Avatar
Just curious, why didn't you ask Mark R. when you picked up your short block?
Old Jul 19, 2023 | 07:18 AM
I’m going to text him and ask, but maybe he’ll see this post. Just wanted to see what others are using.
Old Jul 19, 2023 | 10:30 AM
69 Hurst's Avatar
Olds Fanatic
I run Cometics
x2, they are great.
Old Jul 19, 2023 | 10:36 AM
Looks like I am gonna go with the FelPro 1155. The block was decked, but the heads haven't been cleaned up. The FelPros are more forgiving in that respect.
Thoughts?
Old Jul 19, 2023 | 10:52 AM
It was the opposite for me. I had the heads machined but just cleaned the deck. The gaskets worked great.
Old Jul 19, 2023 | 01:27 PM
fleming442's Avatar
Tough call. It's all about where the compression ends up for me.... I don't know your end goal. 🤷‍♂️
Old Jul 19, 2023 | 03:43 PM
cutlassefi's Avatar
My first choice for an iron headed build are Mr Gasket 5788g’s.
But if you want to use the Fel pros, that’s fine too.
Old Jul 19, 2023 | 08:00 PM
I could get the Mr Gasket ones instead.
Old Jul 20, 2023 | 04:08 AM
Dynoking's Avatar
Thoughts?
Why are the heads not being milled straight? After going through the expense of machining the short block that would be a short cut that I would not take. Any thoughts on this from the pro engine builders here have to say?
Old Jul 20, 2023 | 04:38 AM
Because this engine had been done both on the heads side and the deck after which it had about 3-4 hours of runtime. Then got over revved and spun a coupla rod bearings. I brought it to Mark to redo the shortblock. The deck was cut again to get close to 0 deck with the new rods and pistons. There really wasn’t a need to cut the heads again. However, after going out into the garage and looking at the heads again, apparently, I missed the fact that the gasket mating surfaces have had either a cleanup pass or they are just that clean. Maybe I should go with the Cometics
Old Jul 20, 2023 | 04:52 AM
cutlassefi's Avatar
Or you can do the Mahle 55047’s as well.
Old Jul 20, 2023 | 05:24 AM
Ok, so it really comes down to compressed thickness desires and price since all else seems equal with fresh surfaces. And, lastly, install dry? Or use this: https://www.permatex.com/products/ga...sealant-12-oz/
I've always installed dry with FelPros and never had an issue. I definitely don't want any issues with this one.
Old Jul 20, 2023 | 05:48 AM
I installed those FelPro head gaskets with the Permatex spray.
Old Jul 20, 2023 | 05:56 AM
cutlassefi's Avatar
Everything on the heads is straight. All that was checked when they were done.
Deck was done to 10.615”, which puts the piston .005-.007 in the hole.
And I’d install the FelPro, Mr Gasket or Cometic/Mahle dry.
Old Jul 20, 2023 | 02:59 PM
83hurstguy's Avatar
Cometics (or any MLS gasket) have a surface finish requirement - 50 RA or finer. Smooth finish with no mill marks. Just make sure the machine work was done with that in mind if you go that route. I've never found a reason to use sealers on head gaskets when everything is machined flat, and you aren't doing something crazy like trying to re-use a gasket.
Old Jul 20, 2023 | 03:01 PM
Ah screw it. Mr Gasket it is.
Thanks for everyone's input!
Old Jul 23, 2023 | 06:17 PM
Meigzee71442's Avatar
Head gasket
I use comet they are awesome
pettrix
May 22, 2021 08:58 AM
jb77
May 12, 2021 12:56 PM
scooter123
Apr 21, 2013 09:30 AM
Eddiejr
May 14, 2012 10:40 PM
richeyb
Oct 14, 2010 04:14 PM
