intake gasket/valley pan choice or composite (machine work)
Ok, what's the difference between the FelPro MS96015 and the MS96004? One is $27 and comes with RTV and the other is $34 and does not. They both come with the end rail rubber (throw away).
What is the difference?
Also, should I consider composite intake gaskets? This will cause some requirement to take material off the intake mating faces...
The application data on RockAuto shows different year ranges for each with the break at the ‘72 to ‘73 range where EGR came into use. Maybe it has to do with the exhaust crossover for EGR vs non EGR?
As for composite gaskets, I have used many styles under aluminum intake manifolds with good results. I have also used the turkey tray with no issues. With the composite gaskets I found I needed to retorque the bolts periodically for several months due the cyclic heating / cooling and resulting progressive crushing of the gasket until things stabilized.
Possibly. However, they have the same ports and bolt holes. Upon further inspection of the pics, the MS96015 has a hole in the center bottom and the MS96004 does not. Not sure what this does.
The MS96015 is for later style big EGR passages. Both are Turkey tray style. The 96004 can’t be used with later big EGR crossover because it won’t cover the top over the EGR , but the 96015 can be used with early and late.
here the late 96015 being used on an early 1970 head. The intake casting is the same height , so it will seal ok.
the other issue is it slightly hits the valley in two places and will need a couple hits for clearance.. only did this because the other one wasn’t available
