Used intake gaskets and old valley pan
Old Sep 21, 2022 | 09:35 PM
Isaiah406's Avatar
A few weeks ago I bought a 72 toronado that burned oil for 1500 bucks. I found that this was due to issues with the cylinder head. Had a set of good heads sitting and replaced them solved the issue. I used the original valley pan and a set of intake gaskets not realizing it was wrong. The car has been running fine do I need to redo the intake with a new valley pan and no gaskets or am I risking failure.
Old Sep 22, 2022 | 04:52 AM
If the car is running fine now there's no need to remove the intake and replace the gasket.
I never use the turkey tray intake gasket. Instead I use the side gaskets and ditch the end rails for Permatex form a gasket. You must have gotten lucky.
Old Sep 22, 2022 | 05:50 AM
Long term you will have problems. Change the intake gasket to one or the other. Metal gaskets are not reusable.
Old Sep 25, 2022 | 05:38 PM
Isaiah406's Avatar
Thanks for the advice. Started shooting coolant lol definitely gonna do it right this time
Almond900
May 29, 2016 08:03 PM
1973olds98
Oct 31, 2010 03:50 AM
Wasted
May 24, 2010 06:55 AM
1973olds98
Dec 19, 2009 05:49 AM
mcutlass1969
Jul 12, 2007 04:55 AM
