394 Dual Carbs Questions
Old Aug 17, 2017 | 04:34 PM
  #81
Charlie Jones's Avatar
Phantom Phixer
Originally Posted by bccsrc
Any idea what camshaft this is or who makes it?
No idea on the manufacturer .
I'll take a SWAG , (scientific wild @$$ guess ) that the 280 refers to 280 degrees advertised duration . And the 108 refers to a 108 degree lobe separation . But then I could be all wrong .
Old Aug 25, 2017 | 09:07 AM
  #82
bccsrc's Avatar
So it looks like these new push rods are longer than what Dad was using. I probably shouldn't use these new ones right?
Old Aug 25, 2017 | 01:39 PM
  #83
Phantom Phixer
Please show us a photo of your rocker arms and lifters . You may have some non-standard items .
Old Aug 25, 2017 | 01:49 PM
  #84
bccsrc's Avatar
Without going to storage and taking a picture of them, this is what they look like.
Old Aug 25, 2017 | 01:58 PM
  #85
Phantom Phixer
The rocker arms pictured are non-adjustable . If these are what you are using , then the new pushrods are what to use .
Old Aug 28, 2017 | 08:52 AM
  #86
bccsrc's Avatar
These don't need an oil passage in the middle of the pushrods?
Old Aug 28, 2017 | 05:49 PM
  #87
Phantom Phixer
Nope , this ain't a Chevy .
The rocker arms get their oil from the hollow rocker shafts . Which get the oil through passages drilled in the heads and block
There is a very good drawing of this system in the chassis service manual .
Old Aug 30, 2017 | 07:30 AM
  #88
Tedd Thompson's Avatar
You might wan't to invest in one adjustable push rod to get the correct length for the rest, beings you have mix and match engine parts.... Tedd
Old Apr 29, 2019 | 10:37 PM
  #89
bccsrc's Avatar
So after having the heads rebuilt they have collected some rust. What should I do with them? Take them to Napa and have them cleaned up?
Old Apr 29, 2019 | 11:22 PM
  #90
Phantom Phixer
Yes , good idea .
And while you're there , have them order 16 Melling pushrods . # MPR91 . They should be the right length .
Old May 2, 2019 | 08:15 AM
  #91
coldwar's Avatar
Nice to see your car has been converted to a Jetaway transission, a much more rugged and fun to drive unit then the slim-jim which was original equipment. We used to see this conversion a lot more then seen today, it made a sense then and now as a bolt-in improvement at modest cost.
I agree the push rods with cups are not Oldsmobile stock stuff, looks like Ford to me as has been suggested. The supplier would not know if you have aftermarket rockers of some type with ball fulcrums unless you advised them. Watch the lifter pre-load with a .020 mill on heads and non-standard push rods and potentially other changed valve train pieces. Valve stem contact pattern, lifter pre-load, oiling ring exposure on bottom side of lifter boss with a re-ground cam and reduced base circle, and push rod clearance through the head casting holes at max lift must be verified with these changes.
Good luck ~
Old May 4, 2019 | 01:28 PM
  #92
D. Yaros's Avatar
Am I to understand that a Jetaway will bolt up without a need to modify the floor pan (hump)? If so which year Jetaway is used in this swap?
Old May 4, 2019 | 01:45 PM
  #93
D. Yaros's Avatar
FYI. This link doesn't work. It comes up with:
HTTP Error 404 - Not Found
Brandon
It does not work as the info has been moved to another host. The current/correct link is -
http://graylady.atwebpages.com/CarbRebuild.htm
Old May 7, 2019 | 10:45 PM
  #94
dharlett's Avatar
Nice to see your car has been converted to a Jetaway transission,~
Where did you see this in his post? And how do you put a jetaway behind a 394?
Old May 8, 2019 | 03:59 AM
  #95
coldwar's Avatar
Sorry I missed these replies.
Post #41, the picture of his transmission, it is a Jetaway, perhaps a Pontiac example with a Oldsmobile bell housing. In 1963-64 floor clearance is tight, but since the engine mounting is moved forward for those years, there is a bit more room, although I'm pretty sure some clearance around rear pump location is needed anyway. 1959-60 394 is the trans assembly to use, although somehow I recall Oldsmobile assemblies after 1958 (at some point) no longer have the rear pump tail shaft casting, but I would have to look at some transmissions to clear that up. I don't think flywheel balance is a issue for stock 394 engines 1959 to 1964, but 1957(?)-60 371's flywheel may not work for swapping to a later 394. I also recall guys moved the rear cross member down with new frame holes for more clearance without chopping up the floor, one of my cars had this modification. One other thing I don't recall now is if there is a need to adapt in a earlier two piece driveshaft on a 61-64 car with the swap, perhaps this guy can report if his car has a one-piece driveshaft now.
With some time to think more about it I might add more or correct any errata.
Old May 8, 2019 | 08:30 PM
  #96
bccsrc's Avatar
Got the heads cleaned up and ready to paint.
Old May 8, 2019 | 08:35 PM
  #97
bccsrc's Avatar
The hump has never been modified. Seems like part of the bell housing was ground down for clearance.
Old May 13, 2019 | 04:21 PM
  #98
bccsrc's Avatar
So looks like the red paint on the heads isn't the same as what I had used previously. I'm thinking I might have used this color originally but I'm not sure. The heads were painted with this color which doesn't match.
Old May 13, 2019 | 04:57 PM
  #99
Phantom Phixer
I have seen that on my engine too .
The paint will appear more orangeish when first applied .
It should turn more reddish when it cures longer .
Was it paint from the same can ?
Old May 23, 2019 | 09:15 PM
  #100
bccsrc's Avatar
Might not not be the best picture in the world but here is my dad driving the olds.
Old May 31, 2019 | 10:40 PM
  #101
bccsrc's Avatar
Any idea what size thread that is for the fuel pump?
Old Jul 26, 2019 | 02:54 PM
  #102
bccsrc's Avatar
Progress?
I finally got the engine out of storage and in my garage.
At first I was looking at the carbs and the engine stand thinking it was leaning way forward. But looking at the heads it's not that bad. Any idea how much this beast weighs? This engine stand is rated for 1000 lbs. The 394 has been on here for about 4 years. See the second picture. I'm afraid it might break.
Old Jul 26, 2019 | 03:52 PM
  #103
Phantom Phixer
The engine weighs about 750 pounds , fourty pounds more than a big block Chevy .
You'll be OK with a #1000 pound engine stand . But that's a minimum .
I had a #1500 pound stand , and my 394 wiggled around when tightening head bolts .
Made me nervous .
Old Jul 27, 2019 | 09:05 AM
  #104
Don R.'s Avatar
If you are going to work on that while its on the stand I'd rig up some kind of front support and jack it up a bit.
Old Jul 27, 2019 | 10:48 AM
  #105
bccsrc's Avatar
I think I will come up with something to bring the front end up.
Do you think I can cut this shorter and put a new end on it? It’s 24 inches and I need it to be about 14 inches.
Old Jul 27, 2019 | 02:00 PM
  #106
bccsrc's Avatar
I guess I don't have the head gaskets. Should I use fel pro or is there something better?
$50 worth of paint later.
Old Aug 5, 2019 | 09:36 AM
  #107
bccsrc's Avatar
It's looking like I will need the fuel bowl for the fuel pump.
Do you know where I can get one?
Old Aug 6, 2019 | 06:09 PM
  #108
Phantom Phixer
Here you are ;
https://www.ebay.com/itm/1963-Oldsmo...AAAOSwVcFdSecB
Old Aug 6, 2019 | 09:48 PM
  #109
bccsrc's Avatar
Thanks! I found another seller on eBay asking $60. I think I found the correct fuel bowl on Summit and I found the clamp at the bottom of the bucket.
So I’m waiting for parts now.
I’m about to mount the heads on. How will I know if I need to use the existing pushrods or the new ones that are slightly longer?
Are these rocker arms ok as far as wear and tear?
Old Aug 7, 2019 | 08:22 PM
  #110
Phantom Phixer
It's pretty hard to judge the wear on the rocker arms without complete disassembly .
Do you have a micrometer or a precision caliper ? You will need to measure both the shaft diameter and the " bore " of each rocker arm within .001 inch .
Rocker shafts and rocker arm bores that are more than .001 out of round , are cause for rejection .
Rocker shafts should probably be replaced anyway . Since they are hollow and carry oil to the rocker arms . They tend to harbor dirt and sludge , which you don't want in a " fresh " engine .
Fusick has them for about $50 each ; http://www.fusickautomotiveproducts....p?number=42013
There is also a complete " rebuilt " rocker arm assembly being offered on E-Bay ; https://www.ebay.com/itm/62-63-64-19...e/223591845059
As previously mentioned , a pair of " adjustable " pushrods should be used to determine the correct pushrod length .
The heads should be installed and torqued to spec with the new head gaskets . Install the pushrods on one cylinder and install the rocker assembly .
Bring that cylinder to the "firing" position (to make sure the lifters are on the base circle of the cam ) .
Extend the pushrods until there is no " up and down " play in the pushrods . The pushrods should not be so tight that they cannot be twirled with the fingertips , but there should be no percepitable up and down play . Measure the pushrod length , add .020 (for lifter pre-load ) and order your new set of pushrods that length .
Most cam companies will make pushrods any length you specify .
Once you have all new pushrods installed , check them by bringing each cylinder up to it's "firing" position one at a time . You should be able to twirl the pushrods for that cylinder between your thumb and forefinger easily , but there should be no up or down play .
Old Aug 8, 2019 | 08:12 PM
  #111
bccsrc's Avatar
Thanks for the help.
I disassembled the rocker arm shaft assembly. Sounds like the anchor pin fell inside the rocker arm shaft at some point. So if someone was on a budget... could they pop off one of the end plugs or both and clean it out to save over $100?
Old Aug 8, 2019 | 09:35 PM
  #112
OLDSter Ralph's Avatar
Seems to me that someone removed the ends to clean them out and found a frost plug to press back in. Maybe someone else can verify that. If the pin got inside, you either have a loose hole or you didn't have the right orientation when you assembled and pushed it in. Its been many years since I saw some 394 rocker are shafts. Check the pin fit before you replace the end cap. If it slides in easy, there is a trick for solving that.
.........Just my two cents worth.
Old Aug 9, 2019 | 07:43 AM
  #113
Phantom Phixer
Have you checked the shafts with a micrometer for wear ?
If they are worn more than .001 , they are junk .
Old Aug 12, 2019 | 09:47 PM
  #114
bccsrc's Avatar
The shafts are fine from checking it with my micrometer. I have them put back together now.
I ended up using the old pushrods. When the lifter is sitting on the top of the lobe of the cam I can barely turn the push rod. I'd be afraid to add any length onto them.
I have these 1" and 1 1/2" wide washers that are 1/4" thick. Are these an Offenhauser thing or do I just need to find some of these somewhere. I have misplaced them somewhere.
Old Aug 13, 2019 | 09:07 AM
  #115
Phantom Phixer
The pushrods should be checked with the lifter on the base circle of the cam , not the lobe . The valves will be closed .
This will be when that particular cylinder is the firing position with the piston near the top .
Then turn the crankshaft a quarter turn and check the next cylinder in the firing order . Another quarter of a turn , and the next , and so on .
The firing order of a 394 is 1-8-7-3-6-5-4-2 . The driver side cylinders are numbered 1-3-5-7 from front to rear . And the passenger side 2-4-6-8 .
You should be able to twirl the pushrod between your thumb and forefinger , but not feel any up and down play .
If you are using the old pushrods that came out of the motor you will probably be OK .
Sometimes longer than stock pushrods were installed to compensate for a cam that was re-ground with a smaller base circle than stock .
This was a common practice " back in the day " .
The thick washers on the manifold were an Oldsmobile part ,
You might try PM ing "deadds " or " nailhead canuck " as at one time they were both parting out 394's .
Old Aug 13, 2019 | 02:11 PM
  #116
bccsrc's Avatar
If I can't find the washers should I just double up a 1/8" thick washer? So far I'm not having much luck finding them. Just a little side note, don't get divorced while you have the car tore apart and come back a year later to pick it up.
Old Aug 13, 2019 | 02:24 PM
  #117
bccsrc's Avatar
I did just find some 1/4" thick x 1 3/8". 4 of them for $14.50. They also have 1/8" thick x 3/4". Those are sold in a set of 20 for $28.50. Fusick has these listed for a 1949 to 1960 Oldsmobile.
Old Aug 27, 2019 | 09:11 PM
  #118
bccsrc's Avatar
There was some up and down play with the original pushrods. I installed the new ones and the up and down play is gone. I have this new torque wrench that is a beast and heavy. I probably shouldn't have been using it to torque the rocker arm shaft bracket to head bolts. I snapped one of them smaller bolts off. Darn it! Luckily I was able to remove the rocker arm assembly and screw it out.
I'm waiting on more red paint to finish off the paint on the heads and small parts. I found the washers I needed on eBay. I painted the exhaust manifolds with the POR high temp paint. Looks good. I like the color so I decided to tear apart the alternator and paint it the same color. Hopefully I can get the alternator put back together.
Old Sep 12, 2019 | 09:13 AM
  #119
bccsrc's Avatar
I think I already knew the answer but I was looking into having the valve covers re chromed. I was quoted $225 each and a 6-8 month turnaround. What would be a good valve cover to purchase? The Offenhauser valve covers look nice!
Old Sep 12, 2019 | 09:17 PM
  #120
bccsrc's Avatar
What temp thermostat should I get?
