1967 425 Oil Dipsstick Tube O-ring or not?
Old Sep 7, 2024 | 07:38 AM
Gauchobyte's Avatar
HI All: My oil dipsticks tube become loose, I can't remember if it has to have an o-ring or else which can be the cause of this. Thanks in advance. Best. Raul.
Old Sep 7, 2024 | 08:37 AM
442Harv's Avatar
No O ring.Press fit.
Old Sep 7, 2024 | 08:39 AM
Gauchobyte's Avatar
442Harv: Tx for your answer, wonder why now it become loose.
Old Sep 7, 2024 | 08:53 AM
It may be cracked and ready to break.
Old Sep 7, 2024 | 12:45 PM
Gauchobyte's Avatar
Thumbs up
not at all, almost perfect condition I would say, tried many things to no avail, finally I provoque a small deformation with a vise a hammer it in place. thanks all for your help. Raul
Old Sep 7, 2024 | 05:48 PM
Most times the bulge ring that goes into the block is too large and must be ground down slightly in order to get it into the hole in the block.
Old Sep 7, 2024 | 08:16 PM
Look at your dipstick tube. There are two formed beads and a flange. The tube needs to go all the way into the block until the flange seats against the block. It's likely loose because it isn't all the way in.
Old Sep 8, 2024 | 03:55 AM
Gauchobyte's Avatar
Tx for the heads up Joe!, but yes, I make sure it was all the way down.
Old Sep 8, 2024 | 05:49 AM
Well, that's unusual. Most times the two beads are too large and won't even go into the block. You can try to flatten the bead area slightly, which would ovalize the tube and make it larger in one direction. Also consider a little RTV under the flange when you insert it.
Old Sep 8, 2024 | 06:38 AM
Modest sandpaper abrasion of the two beads then placement of the tube in the (deep) freezer.
Old Sep 8, 2024 | 06:39 AM
His dipstick tube is too LOOSE.
Old Sep 8, 2024 | 06:41 AM
Ooops. I guess my grey matter is loose, as well. Forget that idea!
Oct 15, 2023 10:59 AM
1976Olds
Apr 16, 2021 08:49 PM
Russ
Oct 15, 2017 05:53 PM
jaunty75
Aug 20, 2012 07:07 AM
Jaybird
Jan 29, 2011 01:34 PM
