Real 442 or not
Real 442 or not
I know 1972 is a little different in regards to telling if a cutlass came with the 442 package from the factory. I wanted to get the opinion of the experts here on this car:
https://www.oldsmobilecentral.com/fo...2-Sedgwick.php
Real 442 or not? I like the look of it. Not everyday you see the OAI hood without stripes.
IF it is a factory 455 car, the washer jar should have been on the passenger side fender well. There is an aftermarket rad. overflow jug on the pass. side now, has the washer jar been moved? Or was it always on the driver side? If the 442 appearance package was factory installed on this car, the front sway bar is specific for the FE2 suspension which, I believe, is mandatory with that option package. The passenger side end of that sway bar has a specific shape to it. None of that is for sure, good bullet proof paperwork is about the only to know for sure.
The 1972 could be ordered with a 455 and not be a W-29(442). The standard rear was a 2.73 and could be had with 3.08 & 3.23 because of the AC. There was no 442 badging on the glove box door just Cutlass.
The W25 hood was also an option. Very hard one to tell.
Look to see about holes that have be filled from a Cutlass.
IMO doesnt matter if a 72 is a 442 or not. if its a U or V code you have the more valuable car if you have a 350 powered 442 from 72 its just another cutlass.
there is a 72 442 350ci on Boston CL. IIRC its about $7500 has the w29 too i think he started about 12k ish, it appears to be in nice shape. so if no-one wants a 442 because it has a 350 then what value is the 442 part ?
Looks to be a decent car overall. I think the reason it looks odd is it has no stripes. Although not factory,t says it has a switch pitch 400 which is kinda cool. For $15k or negotiated a bit less, it would make a nice play toy.
Originally Posted by oldsmobilecentral.com
I bought this car in 1998 put it back together.
Manual disc/drums? Wasn't that W-30 4 speeds only? I know my V code Supreme came with manual drums on all 4 wheels. Power disc/drum was an option. Battery in the trunk is strange. Does it have the additional fender braces for a big block car? Is that the correct large snorkel air cleaner?
Front Clip Replaced?
It looks to me like the whole front clip is a different shade of blue than the rest of the car. It really jumps out on the right/front and right side pictures. The rear of the hood sits a little high, also, IMHO.
This ^^^
Manual disc/drum brakes were only available on W-30 4 speed cars. Otherwise you got manual drums or power disc/drums on big block cars. Power drums were not an option.
U in the VIN indicates a 455/Auto, nothing else. Probably a 442, but impossible to prove without a build sheet. Price does seem decent for what the car is though.
Exactly right. Same as V in the VIN indicates a 455/MT, nothing else.
No, not true. A Fisher Broadcast card will also authenticate the car. So will GM Heritage IF the car was destined originally for the Canadian Market and/or originally sold in Canada.
J50 power drum brakes not available on L75 or L77 equipped cars, just as I stated. So yes, other than W-30 cars, big block cars got manual drums or PDB, as I stated. Never mentioned small block cars.
I was only thinking of US cars and meant to say Broadcast/Build sheet so my bad.
Well well well, isn't that interesting? I also happen to have the 72 SPECS booklet and it appears to be contradictory to your booklet, so I looked at the publication date. Mine is effective September 1971, and the one Joe posted from The Old Car Manuals Project is dated January 1972. So in my opinion this is a bit of a standoff. I suggest that Olds likely DID produce some of the 72 models with 455 in 1971 with J50 based on this information. Can you see why I disagreed?
BTW, interesting to note the price drop in 1972 at the top of the page.
In this particular case, the early SPECS manual doesn't prove that any L75 cars were built with J50; it only proves that the combination was not precluded by that document. I suspect there was other internal documentation that eliminated the J50 option on L75 cars, and that was codified in the January update of the SPECS manual.
We just saw a similar issue in the thread on the 74 H/O, were the early documentation showed that the dual gate was included in the Hurst package on all cars built, but later documents clarified that the dual gate was only installed on the 455 cars. Despite that early documentation, no 350 cars were built with the dual gate for 1974. I suspect the same thing happened here with J50 and L75 cars.
I picked up a nicely done clone over two years ago. It was built back in the late seventies or early eighties by an Olds fanatic. It was hard to tell without looking at the VIN.
I have also picked up Frankenstein cars that looked good but after tearing into them it was easy to notice the replaced frame, mix match fenders, etc.
So it really pays to look the car over in person and to see the body language of the seller as he answers questions about car.
Keep in mind that the 1972 model year was a scramble to doll up the 71 models as 72s when the colonnade cars were delayed. There were mistakes or changes to many of the early-release documents as that whole process made it to production.
No, there's absolutely no dispute about your V code car. Wish I had one.
I thought I recognized that order form. The unfortunate part that doesn't really help us resolve the issue is this order form is dated 3/23/72 - which is in compliance with the January 1972 SPECS booklet. What would be really more helpful is an order form from July-Dec of 1971.
Here's the full dealer order form from your post.
EDIT: I just looked at the comparison prices from 71 and 72. The ones being used on this worksheet are definitely from the January 1972 edition of the SPECS. That leads me to believe the worksheet may also be a later edition with different option information listed.
I was able to get a hold of the owner. Nice guy, older gentlemen, has had the car almost 20 years. Bought it in pieces and did put it together. Doesn't really do much driving with it (seems to be more of a pontiac guy) which is why he is looking to sell it. Year One hood. Car didn't come original with it. Doesn't have the build sheet but hasn't dropped the tank to see if its there or not. Says it came with sway bars, definitely is a U code and engine is definitely original and so is the OAI cleaner (but not to the car). Rear-end he believe was from a pontiac. He doesn't like the look of the side stripes typically found on cars with the OAI hoods which is why he kept everything blue. He said its never been in wrecks, the discoloration between the front and the rear is because he just hasn't wet sanded it all since its been repaint. Battery was moved to the back to shift more weight back there.
Overall, seems like a decent to good condition driver car. Without that build sheet, probably no way of knowing what it really came with originally since it has been worked on so much. Its not horrible far away from me, but in the rare case my schedule allows it, I'd like to see it in person.
