Fuel pump
Fuel pump
Can anyone tell me what the trick is to installing a new fuel pump in a BB 400. I have not been able to figure out what I am doing wrong! I have a new pump going onto a newly rebuilt motor that has not been run yet.
Make sure the fuel pump LEVER is pointed
up and the outlet[s] are facing up.
you should have a little resistance when
tighting up the top nut.
If you have more resistance than that, you may have to
rotate the engine a little to move the fuel pump eccentric
some. Hope this helps.
Chris, as tru-blue said you need to have the fitting on the top. Here's an engine on a stand that has a good view of the fuel pump. Is this the way you were trying to install it?
Just to be clear, the "fuel pump pushrod" is a Chevy thing. I suspect you are talking about the lever arm on the fuel pump and yes, it goes upward. Bottom line is that an Olds fuel pump is installed the opposite of a Chevy. If you do encounter resistance due to the lever arm hitting the high point on the eccentric, simply push in harder or as noted, rotate the engine 180 deg or so.
RenderPit
Ninety-Eight
August 6th, 2015 04:55 PM
mefirst72
February 10th, 2013 06:37 PM
Nor Cal Andy
March 29th, 2012 07:27 PM
stlbluesbrother
March 21st, 2011 03:24 PM
