Fuel pump
Old Dec 30, 2012 | 07:24 PM
Chris J's Avatar
Fuel pump
Can anyone tell me what the trick is to installing a new fuel pump in a BB 400. I have not been able to figure out what I am doing wrong! I have a new pump going onto a newly rebuilt motor that has not been run yet.
Old Dec 30, 2012 | 07:53 PM
tru-blue 442's Avatar
Old School Olds
Make sure the fuel pump LEVER is pointed
up and the outlet[s] are facing up.
you should have a little resistance when
tighting up the top nut.
If you have more resistance than that, you may have to
rotate the engine a little to move the fuel pump eccentric
some. Hope this helps.
Old Dec 30, 2012 | 10:30 PM
2blu442's Avatar
Chris, as tru-blue said you need to have the fitting on the top. Here's an engine on a stand that has a good view of the fuel pump. Is this the way you were trying to install it?
Old Dec 31, 2012 | 06:43 AM
Make sure the fuel pump rod is pointed
Just to be clear, the "fuel pump pushrod" is a Chevy thing. I suspect you are talking about the lever arm on the fuel pump and yes, it goes upward. Bottom line is that an Olds fuel pump is installed the opposite of a Chevy. If you do encounter resistance due to the lever arm hitting the high point on the eccentric, simply push in harder or as noted, rotate the engine 180 deg or so.
RenderPit
Ninety-Eight
Aug 6, 2015 04:55 PM
mefirst72
Feb 10, 2013 06:37 PM
Nor Cal Andy
Mar 29, 2012 07:27 PM
stlbluesbrother
Mar 21, 2011 03:24 PM
sshriber
Mar 22, 2010 06:16 PM
