442 on-dash tachometer wiring ?
Old Dec 8, 2009 | 06:40 AM
alexrains's Avatar
Hi Forum,
maybe that question is neither new nor quite hard to answer, but I found nada on the web and my european experiences were also not helpful...
Attached you see the photo of my on-dash tach for the 1966 442 (will sit left/top on dash).
I found out, that GREY is the backlight, but which colour is the tach-pulse, the 12V and the ground..? Shouldn´t there be 4 wires or is the mounting the ground? I really like the fact, that the circuit-board shows the colors and not their meanings.. really different from my european 60´s cars...
Thank you !
Alex.
Old Dec 9, 2009 | 02:42 AM
Yellowstatue's Avatar
Thumbs up Pulse
On a '68 tach the brown wire is the pulse wire from the coil and the case is ground...on yours the black wire should be ground and the pulse wire is brown (I just checked the '66 shop manual pg. 15-46) there should also be a 2 amp inline fuse in the pulse wire near the tach...Merry Christmas...
Old Dec 9, 2009 | 02:49 AM
alexrains's Avatar
Thank you Yellowstatue !
So that means, that this type of tach is not needing any +12V wire, just coil-signal and ground ? Wow, these cars are amazingly simple..
Merry (early) Christmas to you, too !
65droptop442
Jan 8, 2013 09:26 AM
815Cutlass1972
Mar 29, 2011 08:22 PM
Aceshigh
Feb 15, 2011 06:22 AM
425HP409
Oct 27, 2010 07:58 PM
67442HT
Sep 30, 2010 01:39 PM
