Will it fit?
Doc Are you running an eight inch wheel? Never mind . I just saw in your list of items,that you are running a seven inch rim.
Just to run the numbers, a 225/70-14, which is a commonly used tire for these cars, is 26.40" nominal diameter. The 225/60-16 is 26.63" nominal diameter and the same width, so I'd say this will be fine, assuming a near zero offset on the wheels.
Joe I do not know the offset. The owner is trying to find specs as we speak. These wheels are used and came off a 96 S-10 Torque thrust16x8
Joe from the inside hub to the edge of the rim is 4 5/8
http://www.vividracing.com/catalog/-p-70802.html?utm_source=adwordsfroogle&utm_campaign= adwordsfroogle&utm_content=108107&ph=1&gclid=CN-2tZ2rxsACFSMLMgodBigAQg
tmaleck
August 15th, 2021 08:17 AM
