Click Here
Will it fit?
Old Sep 3, 2014 | 01:36 PM
bassinguy's Avatar
Will it fit?
Will a 225-60-16 tire with a 16x8 wheel fit the front of 1965 cutlass with stock suspension? Thanks for your help
Old Sep 3, 2014 | 01:55 PM
doc's Avatar
doc
I am running a 235/60/15 on the front of a heavily lowered '66 F-85 w/o any problems (similar overall height)
Old Sep 3, 2014 | 01:58 PM
bassinguy's Avatar
Doc Are you running an eight inch wheel? Never mind . I just saw in your list of items,that you are running a seven inch rim.
Old Sep 3, 2014 | 02:29 PM
doc's Avatar
doc
...with a wider tire, should be a similar foot print depending on backspacing.
Old Sep 3, 2014 | 03:04 PM
Just to run the numbers, a 225/70-14, which is a commonly used tire for these cars, is 26.40" nominal diameter. The 225/60-16 is 26.63" nominal diameter and the same width, so I'd say this will be fine, assuming a near zero offset on the wheels.
Old Sep 3, 2014 | 03:20 PM
oldstata's Avatar
Justin
I am running a 215/50/17x8 wheel/tire and my tire hits my fender on a hard turn
It's a 65 cutlass 50 year old stick suspension still under it
Old Sep 3, 2014 | 04:03 PM
What's the offset on your wheels?
Old Sep 3, 2014 | 05:07 PM
bassinguy's Avatar
Joe I do not know the offset. The owner is trying to find specs as we speak. These wheels are used and came off a 96 S-10 Torque thrust16x8
Old Sep 3, 2014 | 05:32 PM
oldstata's Avatar
Justin
I am not sure I can measure them if you can tell me where to measure
When I bought the I could chose a 0-+6 if I remember correct and I did 0 in front and the +6 in there rear to get a deeper out side dish
Old Sep 3, 2014 | 05:46 PM
oldstata's Avatar
Justin
Joe from the inside hub to the edge of the rim is 4 5/8
http://www.vividracing.com/catalog/-p-70802.html?utm_source=adwordsfroogle&utm_campaign= adwordsfroogle&utm_content=108107&ph=1&gclid=CN-2tZ2rxsACFSMLMgodBigAQg
Old Sep 3, 2014 | 05:50 PM
dc2x4drvr's Avatar
You might rub at full lock..
mikkim129
Apr 27, 2016 03:49 PM
TOONLOVESCHERYL
Jul 4, 2006 08:07 AM
mikkim129
Mar 26, 2006 09:00 AM
hubb
Drivetrain/Differentials
Aug 10, 2003 10:12 PM
